Question about Panasonic PT-AE1000U LCD Projector
Panasonic AE100U Keeps shutting off
My Unit keeps shutting off within a couple minutes of turning it on. In order to turn it on again i need to turn off the main power switch, turn it back on than press power on the remote. Lately i have to do this 2-3 times before it will stay on. It started long before i needed to change the bulb and continued after I replaced the bulb & Filter and reset the run time. Any suggestions?
  • 2 more comments
  • rondanderson Nov 11, 2008
    I have the same problem. It started a couple of weeks ago. My projector turns off after 2 minutes. After I turn off and then on the main switch I turn on the projector. The projector runs fine for hours then.
  • basementdoc Jan 28, 2009
    My unit started doing this EXACT thing just a few weeks ago. Did any of you update your nvidia drivers (8800 gtx)? That is the only thing I can think of, other than a broken projector.
  • zachbates Mar 18, 2009
    runs for aminute or two then shuts off. Have to turn main power off then on to make it turn on again. No noticeable change in picture when it happens.
  • mstrat Apr 12, 2009
    I have the same problem exactly -- has anyone found a solution
Sounds like a lubrication problem to me. Are any of the optical lenses lubricated. If so, sounds like a bad Grease Problem that should have never happened in the first place.
Panasonic should rectify this problem since it also occurred with my projector when the lamp was less than a 1000 hours. old.
Posted on Aug 05, 2009
I have exactly the same problem. I was told by Panasonic sales rep that a shipment of AE1000U projectors came in that have a faulty board (he thought optical board but wasn't sure). Only solution is to replace the faulty board.
Posted on Nov 08, 2008
I am not sure if this is the same problem, but my projector was suddenly powering off completely, no indicator lights at all, after about 10 or 15 minutes. It would not power on either with remote, on/off switch, or wall power. After much fooling around, I found that if a moderate amount of pressure was applied between the two control dials on the top, it would power on. With some strapping, a small piece of wood, and a tap and bolt, I was able to permanently apply the needed pressure and my projector works like new.
Not pretty, but I did not have to crack open the case or send the unit in for maintenance.
Posted on Jan 11, 2010
Mitsubishi ac keeps on turning itself off
If the compressor overheats, the clixon circuit will shut off the power to the motor to prevent damage. Then when it cools it will close the circuit and the compressor will again run to only shut down again.
The suction line going to the compressor should be cold - the cold gas returning to unit cools the hermetically sealed motor. If that line is hot you may be low on refrigerant.
Feb 19, 2014 | Heating & Cooling
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
Tv wont turn on< red power light just keeps blinking?
I have the same thing. Just started blinking 10 times. Pretty much had to unplug the unit over night. Could never turn it off and then turn it on again.
This worked for about a week. This morning, tried to turn it on after being unplugged. Still blinks.
Called Panasonic. they attempted a couple solutions, nothing. Suggested authorized repair shop.
Aug 20, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My viera plasma 42'' turns on and shuts down
If it has warranty left get it in quick. The starter solenoid is damaged and eventually will fail comkpletely taking with it some more parts.
Thanks for using FIXYA
Sep 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
Dh305y6 keeps shutting of within minutes
sounds like you need to replace your humidistat control. this is just like a thermostat on an air conditioning system, except inside of sensing temp and turning off, it senses humidity and turns off.
Jul 02, 2009 | Goldstar DH504EL Dehumidifier
TV shuts down and blinks red 6 times
Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
Nov 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
SX-SR604 KEEPS SHUTTING OFF
Los amplificadores de audio estan empezando a fallar.
Mar 13, 2008 | Onkyo TX-SR604 Receiver
Camera just won't work!!!
Are there any error codes on the screen? It sounds like your unit has a moisture problem or needs reset. Do the reset first. Remove the battery for about 30 minutes, reinstall and see what happens. If this doesn't solve the problem leave the unit in a dry area with the cassette door open for a day and then try it. If it still will not work you could have a bad moisture sensor (or most any problem) which will need replaced. If you are not capable of electronic repair you will need to find a reputable repair shop. Here a some websites which offer free estimates and may be helpful: http://www.videotech.com or http://www.camcorderrepair.com or http://www.videoonerepair.com Good luck.
Jul 25, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic PT-AE1000U LCD Projector Logo
1,169 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
