The proiblem should not be too complicate.
Can you please click the right button of mouse on the picture file, chose properties, and tell us what is the file extension (AVI, MPG, JPG etc.)
Nice so everything is fixed
Adobe Systems who don't certify to LSB, though, they often use LSB as a stepping stone in the certification process
Is the picture edited with a PC or recorded with a digital camera from another manufacturer
This may also happen if the battery is removed immediately after recording or if recording with a exhausted battery.
- Format the data to delete the pictures mentioned above.(Formatting
irretrievably deletes all data including the other pictures. Check the
data carefully before formatting.)
If the battery is inserted or removed when the camera is not turned off, the recorded folder numbers are lost.When you perform an
operation after taking a certain action, the pictures may be recorded
in folders with different numbers from the ones used prior to the
operation.
However if you turn the camera on again and record pictures, the
recorded folder numbers are different from the prior recorded folder
numbers.
What do you mean you cannot download it to your computer? computer is not recognizing the camera of the video is not there? please clarify, If the video is save on the memory card of your camera try putting that mermoy card on a card reader and download the video that way...
Hope that helps.......
So you're saying that the paricular video is missing and only shows photo when the camera is connected to your computer? I believe there's some folder there where the video is being save can you please check all the folders...
Is the camera connected to your computer or just the mermory card via a card reader? there's possibility that the video was save in the camera built in memory or to the memory card...
So when the camera is connected via USB cable what are the folders there? check all the folders i think its just save on another fiolder since you can play it on your camera....
Connect your camera to your computer. you should see the camera in my computer, open the camera folder, the movie should be in there.
optionally if you recorded it into the memory card, you could remove the memory card from the camera, plug it into a card reader - connect it to your usb port and then copy the movie from it to your computer.
Are you sure you took video instead of a picture? can you play it on the camera?
you can use the windows movie maker to make the clips into one movie.
Download and install ffdshow
http://www.free-codecs.com/download/FFDs...
It might help you with the picture issue, let me know how it goes.
and I suppose your unable to see mine?
Take the first one,
or this
http://www.free-codecs.com/download_soft...
open up the zip file you downloaded and run the setup file inside in the setup you basicly needs to press next next next next and finaly finish. now try if you see the video instead of just a picture.
the file you downloaded, double click it, it opes up, theres a file in there with a long name, double click that file, the setup / install comes up, just keep clicking next next next to install the codec.
No problem, so hows it going with the codec?
can I have a look with remote support?
goto www.fastsupport.com
Enter your name or nickname
type in support key 795-790-151
use the
manually download software linkand click "Run" or "Open" when prompted. (You may be asked twice.)
people have had problems with the automatic one.
I opened a new session
the number is 259-207-509
test
So I can download it but it downloads as a picture.
I also have many different clips that I need to make into a movie
That is the program that I am using. But when i hit play it just shows the picture. Also I can play the video on my camera
the only folder is october 6. That is the only folder that it is saved to
I had it in the card reader but then someone told me to get teh cord so i did. It is saved to the memory card
Can it be saved in two places? Also there is only 1 folder.
I need another solution becasue this is not working. There are not 2 folders there is only 1.
ok i just am getting to the website thank you. I will let you know if this works
yea that is how it was. how can i choose who i can see
once i go to that link and hit dowload, it takes me to another page with six different links. which one do i choose?
ok i downloaded it. what do i do know?
Im sorry that i am bad at computers. But waht is the setup file?
What?
That does not mean anything
ekse those last 2 comments are not meant for you. someone else was trying to help but was not doing a good job at it
when i double click the picture it just gets bigger. there is no longer name
is the file the picture? and if it is then when i double lcik it it just blows up
ok i need to log out and log back on. cuz i was on a different computer. so that wya you can see the screen
ok i am on
This person saved my life!! I cannot tell you how much this helped!!
The Solution and assistance that ESKE provided was invaluable (last week). The problem was solved then and, with much gratitude on my part!
thanks
gerandran
