Question about Mantis 2-Cycle Tiller
My tiller won't stay running
My tiller will start but will not stay running. Cleaned the spark plug and cleaned the air filter.
  • Anonymous Mar 26, 2014
    We have replaced spark plug and coil and cleaned upper portion of engine. We are now getting a spark, however tiller will not start.
  • 48 Answers
This is a two cycle with a walbro carb - probly need to remove carb to flush and put new diaphrams in
Posted on Oct 17, 2008
  • 122 Answers
How long has it been since you last used it? - drain the tank and try a fresh gas mix.
Posted on Nov 27, 2008
Hello I checked the spark plug and cleaned the carb on my 5hp engine on my roto tiller. It still wouldn't run. Any help will be greatly appreciated.
Hi Marin:
Did you check the plug for a hot blue spark?
Did you drain the carb to make sure there are no contaminates?
Fresh fuel?
Clean air filter?
Correct oil level?
Try a squirt of gas into the carb to prime it.
May 19, 2015 | Garden
Won't start,charged oil,cleaned spark plug and air filter.has gas.
If your tiller has sat for any length of time it may have stale gas and the spark plug may need replacing (not just cleaning). Always make sure all wiring and or connections are clean. You can check for spark by removing spark plug, insert it back into spark plug wiring, using a WOOD clothes pin to hold the wire, hold spark end of spark plug (holding the clothes pin only) on metal casing on machine, pull starter cord and check for spark. If you don't use a non conductive instrument such as the clothes pin you will get a nasty shock. If you have no spark it is time to change the plug. Always put your safety first! Hope this helps! Have a great day! If this doesn't work perhaps you will need more information.
Mar 30, 2015 | Troy-Bilt Pony Garden Tiller
Mantis tiller 7222e
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
Jul 09, 2014 | Mantis 2-Cycle Tiller
Carburetor cleaning
check air filter . remove filter run scooter see if that fixes problem . if it does buy new air filter
Jul 14, 2013 | 2007 Peugeot JetForce 125 ABSPBS
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Engine will crank with starting fluid, but dies.
Have you checked the spark plug and see if its clean and also check the fuel line and carburetor for clogs. And you can also check the air filter.
Hope you find this helpful.
Jul 09, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Mantis 2-Cycle Tiller Logo
1,768 people viewed this question
Top Mantis Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
