LG HT762PZ & RH387H Remote control problem
I got one DVD player and DVD recorder and both are come from LG.
Therefore, both remote control can control one to another. Thus, the problem is obvious that when I use the remote control to power off the DVD player, the DVD recorder is also switched off too. When I press eject disc button, both will release the disc tray.
How can I solve this problem?
I have already contacted the Customer Service of LG and they replied no solution at all and this symptom is very common to other brand device.
Grateful for your assistant to solve this problem. Thanks
5 Suggested Answers
  • 20 Answers
SOURCE: lg remote
Assuming you have not shot your in-laws and are now reading this from a jail cell, if you hold down 'TV POWER' and press number '8' or '9' on the remote, you should get it working again. I've just got a new Sharp bells'n'whistles TV, and the remote doesn't work fot it at all. Bummer!!!
Posted on Jul 16, 2008
  • 86 Answers
SOURCE: omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Posted on Oct 04, 2008
SOURCE: Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Posted on Mar 01, 2009
SOURCE: Universal remote control with auto-search to find unknown device
http://www.envizage.com/p/737959/sumvision-zengo-remote-control.html
Hope this helps, Stan.
Posted on May 30, 2009
ricomun
  • 24 Answers
SOURCE: SONY Remote Control - some buttons do not work.
Usually this means the conductive contact on the back of the rubber pad has worn down and cannot connect the circuits on the remote controls main board. There are several ways to fix this.
#1 Find some conductive adhesive or paint and carefully paint the back of the button tab ( let dry completely)
#2 Rear window defogger kits are available at most reputable auto parts shops and contain a paintable adhesive which you can apply to the back of the remote control button.
#3 try super gluing a small piece of aluminum foil to the back of the button tab.
I have used all 3 and they all work good.
Posted on Jul 02, 2009
I have a one for all remote urc 3021 need code for LG DVD PLAYER
Glenda, remote urc 3021 code for LG DVD PLAYER, LG dvd try codes, 0591, 0869, 0741, 1906
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7692/~/programming-the-one-for-all-urc3021-universal-remote-control-(3-devices)
RC LG DVD Codes
How to Program Universal Remote Codes for Universal Remotes
Aug 25, 2016 | One For All Televison & Video
Program hisense to work LG DVD player
Hisense remote control have no set-up codes with LG DVD player.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 17, 2014 | Televison & Video
How do i program my mitsubishi remote to my lg dvd player?
If your Mitsubishi remote is programmable, you can use its code search feature to find a code for your LG DVD player.
Jun 09, 2014 | Mitsubishi New Original 290P137C10 Remote...
Can i program my LG remote AKB73615316 to my Magnavox DVD player?
You can if your LG remote is programmable and you can find a code for your Magnavox DVD player
Dec 23, 2012 | Televison & Video
Model no wv10d6 ge remote control code
You have a GE universal remote and you want to control a (brand?) DVD recorder and a (brand?) DVD player
Nov 29, 2012 | Televison & Video
Need instructions to program DVD Rec.Remote
Get the manual or figure out from LG's website about the thing,the site should have a download of the manual for the thing
Jan 03, 2010 | LG Electronics/zenith 6710t00008 Remote...
Televison & Video Logo
427 people viewed this question
Top Televison & Video Experts
Electro Med Services...
