Question about Lexmark C524 Laser Printer
C524 has narrow vertical slashes down left hand side
Print outs have blue vertical lines interspersed down the left side of the page about 2mm and 2cm from the edge. Both the toner cartridge and the photoconductor unit are new.
  • 2 more comments
  • joakridge Dec 02, 2008
    Print outs have blue vertical lines interspersed down the left side of the page about 2mm and 2cm from the edge. Both the toner cartridge and the photoconductor unit are new.  I have also swapped out the photoconductor unit and toner and know these are not the problem.  Someone had said that possible cause of problem was locking tabs being broken that hold the developer.  Does developer mean toner and where are these tabs?
  • joakridge May 11, 2010
    What is meant by developer and where are these locking tabs/clip?
  • Anonymous Mar 15, 2014
    lines down the left side of page pencil rolled into paper slot, removed by easing forward the roller
  • Anonymous Mar 21, 2014
    Vertical Repetitive defects on first 10-15 pages of printed paper
    Novelist:
  • 188 Answers
This problem is 99% of the time the photoconductor. Try removing and reseating. If this does not work, try another one. Even though you state that you just replaced it, on rare occasions, defective ones get shipped out. Usually the manufacture will replace the defective unit for you when this happens. Also make sure that the locking tab that holds the developer in place did not crack and therefore loose. I have seen this many times where the clip that holds the developer is damaged.
Posted on Oct 06, 2008
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
A blue line , 2mm, appearing at bottom of page.
Hi Info39684,
It sounds like your Cyan imaging unit has gone down.
Have you thought of changing the orientation of your paper from A4 protrait to A4 landscape. If the blue line is at the bottom, changing the orientation should hide the problem. It's not going to fix it, and if you use A3 then you will see the line again. It's just an idea and you could save yourself £250 on a new unit.
Regards
Taminol
May 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Full Cyan Cartridge Does Not Print At All in Lexmark C524
It could be that your PC is expired
"Photo Coductor"
Apr 28, 2009 | Lexmark C524 Laser Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Light grey vertical line printing on left side of paper used the cleaning cycle and line in now doubled There is a black vertical line down left side of the page. I used the cleaning page but the line is...
I believe there are 3 possible causes for this issue; toner drum, fuser or transfer roller - more than likely I would dismantle the printer and check for lines on the fuser. But just in case remove the toner and carefully release the flap to reveal the toner drum - if that is scored and the lines correspond to those on the print-out thats the cause.
Rgds Colin
Dec 09, 2008 | HP LaserJet 2420 Printer
Why do I get a line of faint or no copying on the page?
Does this blank line run top-to-bottom or side-to-side, and which direction is the paper traveling through the machine, portrait or landscape?
Jun 03, 2007 | Minolta EP1031/1031F CS/PRO Copier
Lexmark C524 Laser Printer Logo
374 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
