Question about V-Moda Bass Frequence Bling Bling Black Consumer Headphones
Left bud not working properly
Ive been using these earphones for almost 9 months and all of a sudden the left bud is very very soft. i tried switching them around to make sure it wasnt just my ears but its definately the earbud itself. i took the rubber ear canal thing off and cleaned all of it but they just arent working right! i dont know what to do now
  • koolkash Nov 29, 2008
    I have the exact same problem, and so does my friend. My earphones work fine perfectly but the problem occurs when I plug them to my laptop (Alienware m15x). The sound does not completely go in the left bud, it just goes very quiet.
Same thing happened to me today, so i took out the mesh to see what was going on.  Like solution 1, the mesh was the problem and i removed it with tweezers but i couldnt help bending the mesh a little.  Its not that its a problem of the mesh touching the cone but that the adhesive that attached the mesh was covering the whole underside of the mesh along with some wax.  I removed the silicone adhesive with the tweezers and washed out the wax with some peroxide.  The trickiest part is getting the mesh back in.  I put one side of the mesh in with the small lip facing down, slightly bent it so it made a bump on the top of the mesh and maintained its convex shape and then squeezed in the other side with trying to keep the lip in while doing so.  Took me a few tries but after you get it in push the edges in so they don,t come out again and file down the edges if there are any sharp pieces of the mesh protruding.  And your done.  Solved my problem, hope it works for you.
Posted on Feb 26, 2009
The same happened to me, and the reason was rather surprising. The metal mesh on your earbuds is most likely coming into contact with the speaker cones inside the earbud. The most probable reason for this is the buildup of earwax in the tiny gaps in the mesh. The easiest (but not entirely attractive) solution would be to use a small grabbing tool, like a tweezer, to carefully pull out the mesh and clean out anything inside the cone tubing, and then carefully push the mesh back into place. Do not be afraid to scrape off any gunk buildup on the mesh itself on both sides before replacing. Be careful not to push it in too hard when you are done, as the cone could still be blocked by the mesh. Once you are done, put the rubber cone back on and enjoy your music at normal volumes again! I fixed two sets of earbuds like this that I originally thought had a dead right earbud but was delighted to have them both working beautifully again after cleaning! It beats paying 30 bucks for another pair, and now I have a spare pair to fall back on.
Posted on Dec 30, 2008
  • 103 Answers
Hi
If you are good at DIY and you have the tools try opening the Left bud, remove the wires and resolder them back in place. If you want to save the hassle of all that I'd suggest that you get a new pair of ear phones. The ones you have have lived their lifetime.
Genius Guy
Posted on Oct 17, 2008
One of the ear buds on me ifrogz earpollution headphones just stopped playing music. I haven't been dragging them around or getting them wet or anything, and they're only a couple of months old. The other...
I had same problem. 1 of earphones stopped working. If i turn up volume, some sounds gets through, but then the other earphone would be blasting. Used them running so maybe sweat or earwax clogged them, but the problem didn't start until 1 month after stopped running.
Mar 07, 2011 | ifrogz EarPollution Plugz Headphones
My dad just got me these new skull candy earphones ive had them for about a month and a half at night i wrap them up neatly when in my pocket i wrap them around my ipod and now i dont know why but the left...
This is very common with Skull Candy headphones as the jacks are very poorly made. I went through 4 pairs of them within 4 months. Unless you want to buy a new pair every month, buy a reliable brand (Sony, Panasonic, etc.). You can however get them replaced with the same product by visiting:
http://ca.skullcandy.com/warranty-information.html
Hope this helps
Mar 05, 2011 | Skull Candy LINK Earbuds Consumer...
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
My skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Philips SHE9550 right earphone is louder
Your current solution to solve the difference in volume (the piece of paper) is not far from the problem.
Your problem is earwax. I have the same earphones and had the same trouble. I checked cable and plug but they were all fine. So then I checked for earwax. It didn't look like I had too much on the rubber plugs - removed that. The problem was what was on the nets. There was some visible, I tried my best to remove that with a sharp knife but the problem remained. I tried to remove some more and found that you can remove the nets easily with a sharp item - just pull them upwards.
There was quite some on the inside of the nets. I thoroughly scraped it all off with the same knife. There can very well be better ways to remove it but this worked perfectly for me.
When all was gone, I tried the earphones and was shocked at how much the volume had gone down in both ears (more in one) before the cleaning.
I hope this helps.
Mar 13, 2009 | Philips Audio Players & Recorders
Only have sound on right side
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
Dec 25, 2008 | SanDisk Sansa e260 MP3 Player
Logitech wireless earphone not connecting
the problem may be in logitech earphone......after using some days....it may have got repaired....if it is repaired then the connection problem will come....otherwise if you are using antivirus....check the firewall.....if the firewall is not allowing skype to connect to internet....these problems will arise....i am a software engineer and i have experience in these areas....thats why i am suggesting this idea....try this...it will work.....
Sep 19, 2008 | Logitech Cordless Internet Handset for...
R225M earpiece problem
If you bought a clone or non original earphone it can do that on your phone. Some of the PDA models are also very critical to the circuit wiring for the earphone, the switch, and the impedance.
If you are using the original earphone, and have this problem, it may be that there is a defect in the wiring, or the phone has a defect in its circuitry that works with the earphone.
Jerry G.
Jun 02, 2008 | Samsung SGH-R225m Phone
V-Moda Bass Frequence Bling Bling Black Consumer Headphones Logo
1,747 people viewed this question
Top V-Moda Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
john h
Are you a V-Moda Audio Player and Recorder Expert? Answer questions, earn points and help others
