Question about Photography
Canon AE1 shutter problem, shutter will not release
Hi, as you advised we removed the bottom of the camera and can get the shutter to release by pushing the lever over, but continually have to do it. The meter reads fine. How do we check the magnets?? Thanks so much.
  • 667 Answers
Well, here is where it gets a little tricky. You'll need an x-acto knife, some lighter fluid and some q-tip swabs. You need to carefully cut the plastic shield on 3 edges to make kind of a door to the magnet.
You are doing this to expose the magnet face so it can be cleaned with the lighter fluid using the cotton swabs. Careful how you make the cuts.
Posted on Oct 14, 2008
I cannot press down the shutter release and the film advance tab will not move, therefore making it impossible for me to take photos. Please help.
I guess it is actually an AE1 and not an EOS, as EOS is a digital camera! You will have to scrap the film in the camera by opening the back and removing the film. Take out the film can, then pull the film off the take up spool press the windback button on the bottom of the camera. This should get it working again. Try a few shutter releases and wind ons before putting a new film in. If you have important images on the film you don't wan to lose just do the above in complete darkness, and wind the loose film back into the can using the knob at the bottom.
Jan 04, 2011 | Canon EOS-AE-1 35mm SLR Camera
My AE1 is malfunctioning. The shutter is being released when I advance instead of allowing me to expose the film with the shutter button.
Hmmm. Sounds like something internal is not engaging as it should. It probably is a plastic gear that has aged a little too long, and some of the teeth are broken off. Yes, this will need a trip to the repair shop. It's probably due for Clean, Lube and Adjust anyway.
Garryscamera.com and many others will repair this camera for you. Luckily, AE-1 was a great seller for Canon, so there are lots of spare parts out there. On Ebay, they are inexpensive and common. Buy one as a backup or parts donor, as they are old enough to start falling apart.
Apr 27, 2010 | Canon EOS-AE-1 35mm SLR Camera
Ae1 when i advance film the shutter releases abd takes a photo
You have bad mirror release magnet.
The magnet became weak and not holding the mirror so when you wind, the mirror goes up and takes pictures or releases the shutter by itself.
Canon AE1 program film advance locked
The cost of fixing is almost the same as buying a used or refurbished AE-1 about $80-120
Dec 21, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae1 shutter button problem
Usually cleaning the contacts becomes an effective solution, but if the problem continues take the camera to the service. All shutter problems requires professional care.
Sep 23, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Sep 17, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shutter squeal, Canon Cough a1 Ae1
This is in german. Look hard at the pictures. You only need to remove the bottom plate. Use a hypodermic needle loaded with just one drop of non-acidic oil. Practice first. Stick the battery back in an operate the shutter 30 times. leave the camera overnight upside down.
www.aldo-net.com/Canon/
Running the text through Babel will give you a good idea. It does work.
Bob-S
Sep 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
AE-1 self timmer
The battery is not the problem. It is more likely the the internal switch has failed, (always stuck on self timer). The switch is a ring around the release button for the shutter. The small black tab covers the red LED in normal release mode, the self timer is on when the tab is facing forward.
Jun 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Meter on ae1 not working when aperture setting adjusted
On that camera the needle is not supposed to move when the f-stop ring is turned. It should stay on whatever number it is on and you should set the ring manually to whatever the needle points to.
That camera was really not made to be easy to use in the manual mode. I guess Canon thought everyone would just use it in Auto.
CameraRepairs
May 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shuuer stuck down, lever wont advance
The Canon AE-1 has an electronic triped shutter and cocking system and requiires a battery to function. So yes the battery is required. Goog luck!
Aug 26, 2007 | Canon EOS-AE-1 35mm SLR Camera
Photography Logo
151 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
