Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Hoover Dryer 5030D does not heat up
My hoover dryer has been working fine now it just dies not it up anymore, what can I do?
  • Anonymous Mar 16, 2014
    fuse blown
  • 750 Answers
Huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Oct 06, 2008
Hoover 5030d dryer I have to spin the drum to let dryer work. What is the problem? Where can I find the spare part?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Dryers
Hoover dyrer 5030d not getting warm
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 03, 2011 | Hoover Dryers
Hi i have a hoover 5030D cloths dryer and it dosent heat up when in use can you tell me if im able to repair this my self and where i can get parts. regards Bill
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 31, 2011 | Dryers
Hello, i have a hoover dryer, model 5030D, secondhand, it is just been purchased my us. we put on our first load on and the machine stopped within 15minutes. we noticed then that the machine was...
Hi, if I remember correctly this model originally came with 2 faceplates so the controls can still be easily accessed, when the dryer was installed upside down on a wall. Most dryers can be run upside down, or even on their side as I done in the past with my Hoover 5030D, so the problem would lie elsewhere.
Dec 26, 2010 | Hoover Dryers
My Hoover dryer model 4030D heavy duty needs a new
HI. you can order your timer by calling this number. this is a parts store that will ship your timer to your door step or mailing address..
1-866-925-PART (7278)
Just tell the Representative your model number and brand name of the affected unit and, they will search for it on there data base. when found, they will ship it to you after you purchase it.
Jun 18, 2009 | Hoover Dryers
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
171 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
