No current through plates.
Power light is on but no current through the plates even when using test button.
Bought a new one.
Posted on Oct 06, 2008
07 impala rear defogger grid does not heat up, but it has current
there's a defect in the grid somewhere and trace it till u find the spot! once u find the spot find way to fix it! might have to replace rear glass!!
Mar 25, 2013 | 2007 Chevrolet Impala
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
My garbage disposal isn't working. it doesn't even make a sound when i hit the switch. i checked the circuit breaker and it's not that...i pushed the reset button underneath and it didn't help, either.
On the bottom of the disposal there is a small red reset switch. Push it in and see if it stays. Turn on switch and see what happens. If it hums or buzzes take a 1/4 inch allen wrench and insert it into opening in the center of the bottom. Turn wrench back and forth while running hot water through disposal to help clear any blockage. Turn on switch on and see if thats helped. Thank you.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Doesn't power up, power light flashes 3 times when power button is pressed
Hello mate,
check that:
1. power supply is connected correctly to the electricity and from the other side to your laptop. 2. there is normally a light on the power supply, make sure that this light is one. in case it's off, that means the power supply is broken. 3. There is a charge light on the laptop which should be on once you connect the power supply to the laptop even tough the laptop is off. if this light is off, that means: a. the power supply is not passing the current to the laptop: you may test with another power supply. b. the power connector on the laptop is broken.
In the worst case, the motherboard maybe broken.
Oct 29, 2009 | HP Pavilion dv9000z Notebook
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Cannot diagnose source of electrical fault
TRY A TO BYPASS ALL SYSTEMS WITH A POSITIVE LEAD SHOULD WORK BUT YOU NEED AT LEAST 9VOLTS TO GET THE IGNITER TO EVEN THINK ABOUT LETTING THE COILS HAVE ANY POWER TO EXPLODE THE GAP POINT OF YOU'RE SPARK PLUGS SO GOOD LUCK
Jun 14, 2009 | 1997 Yamaha XVS 650 Dragstar
Licensce plate light
start with the obvious check the fuse in the dashboard if thats fine i would say pull the bulb out again and try putting a test light to it and see if its even getting power if not it probably a short in the wiring
Oct 27, 2008 | 2000 GMC Jimmy
No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Jul 20, 2007 | Kenwood KDC-2019V CD Player
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
