SOURCE: Toshiba 57HX81 57 in. Rear Projection
Im guessing the the convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: picture blurry
try doing a magic focus
SOURCE: 57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
SOURCE: When I turn on my 50H82 it takes 10 to 15 minutes
I just did a repair on one of these. Check your picture-on-picture. If the the secondary picture is clear, chances are very good the problem is on the "hyper board". We d not replace the hyper board - we repair it. The board is very expensive and rarely, if ever, available. There are several parts in the module that need replaced, but these are definitely not user replaceable. They are very small surface mount components and even I have lifted a copper or trace or two doing these. It is tedious work but our repair bill was well below $300. It is also something I do not do in the home and taking it to the repair facility is a money saver. I did go to the home on this one and remove the board to the shop, however they only lived a few miles away so the service call was low priced. Hope this helps...
SOURCE: Toshiba 50h72 picture and sounds takes 20 min to warm up
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
I have the same problem, tv is 6 years old and have been lucky. Called the cable company in case it was their hd box and gentleman said it look like a focus problem with the tv. Any solutions?
