Question about Fujitsu Plasmavision PDS-4209 42 in. Television
Screen shuts itself off & power light blinks
After 3-4 hours then I have to turn it back on again.
Take the back of the unit off and dust the fans. You an keep it on the stand, take off the top & side row screws then peel back the rear cover to get access. Make sure the little mesh vent holes are clear and have no obstructions. I am so very angry about this device and the aggravation I have had with it. So far, I have spent $7000 on this unit and will not spend another dime on it. If it breaks again, I'm kicking it to the curb & buying a 46" Samsung Touch Of Color
Posted on Apr 26, 2009
Rca flat panel tv turns itself off. LED light on pwer button blinks 3 times,but wont turn back on
With the model which is not indicated here Google that for 3 blinks to know what the error code means.
Dec 23, 2012 | RCA Televison & Video
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Screen went black an hour ago, the sound is ON
Start by replacing the bulb. If thats a no go, check the ballast. Its a small circuit board directly underneath the bulb housing and is replaceable through the bulb panel. If those two don't work, comment back and I'll walk you through more 'in depth' repairs.
Feb 02, 2009 | Samsung DLP HL-P5663W 56" TV
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Open Questions:
Fujitsu Plasmavision pds-4208 Display randomly hey everyone =D any help would be greatly appreciated! this is my problem... i have this plasmavision it has been working fine since i got it, now all of a sudden the picture will just disappear, as its only a display unit and I'm running my audio thru my home cinema system. its an intermittent fault but its been progressively getting worse, sometimes a sudden display change will cause it to stop working, a total display loss with no osd... however green light continues and the psu still carries on operating with fans going... until a couple of minutes when it will shut itself down and display an orange light for no input signal. Ive had the psu out and tested all the connections as i have the service manual but no schematics. when the unit is fully operational all output voltages are correct but a few which maybe a volt lower or higher than stated. however when the unit stops displaying a picture, the x and y sustain outputs drops its tension... only one connection does this on the CN49 on the Ve pins for both x and y sustains the tension drops from nominal 16v to 4.2v i have removed the sustain connectors to power up the psu and funny enough... without the sustain boards connected the pin has only a 0.2v output this is really confusing me now. Its a bit of a bummer too as i have no schematics to follow *puh* am i right in thinking this is solely a psu problem?... or maybe a faulty digital board?.. seeing that the display shuts itself off due to no signal? or could it be a faulty sustain board? does anyone know whats going on or had this problem before? kindest regards to all... Jay jaydeeks(at)hotmail.co.uk
Feb 01, 2010 | Fujitsu Plasmavision PDS-4209 42 in....
Fujitsu Plasmavision PDS-4209 42 in. Television Logo
139 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
