Question about Kenmore 73952 Gas Dryer
Gas dryer I cleaned all ducts.
  • earks Oct 06, 2008
    Yes.
  • 943 Answers
Did you also clean the air duct, in the dryer, where the lint filter goes. dirt gets in there as well .
Posted on Oct 06, 2008
No air at vent
Sound like you need to replace the heating element.
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Jan 01, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Tip
When to Buy a New Dryer or Fix Old One?
If your old clothes dryer is not working well, how do you tell if it's time to replace it?Here are some things to check before you set it on the curb with a"FREE" sign.
If it still turns on, runs a proper cycle, doesn't make a lot of squeaks and groans, and your clothes are at least attempting to dry, then check the following before you decide to replace.
1. Check and empty your lint trap before each load. If airflow is restricted, your dryer will need longer to get the job done. A clean lint trapwill allow for maximum intake air to the dryer blower.
2. Check the exhaust duct work for lint buildup. If the 4" duct work that carries your warm, moist, lint-laden air to the exterior of your home is blocked with years of lint and moisture, chances are pretty good your dryer is taking longer than it should to get your clothes dry.
  • Disconnect the dryer power cord (and gas line if a gas unit), slide the dryer forward far enough to access the 4" duct work clamp at the back of the dryer. Disconnect the duct work at the dryer and separate to inspect both in the dryer exhaust duct and the duct work as well.
  • Remove all built up lint. You may need to access under the floor, or in the crawlspace, or basement to get at all the areas that lint may be built up. Remember that when there's an elbow chances are pretty good there's lint in there, so take the time to separate the duct work where needed to give it a thorough clean out.
  • Long straight sections of duct work can be easily cleaned by using a Webster-style pole brush.
  • Clean the exhaust duct of the dryer but be careful not to damage anything inside your dryer
  • Reconnect and turn the dryer on air fluff to blow the rest out.
3. Remove lint build up from inside the machine
  • Turn power off again
  • Remove the front cover of your dryer
  • Remove the front drum support/air duct from the front of the dryer
  • Carefully vacuum the lint out of the dryer with soft brush attachment on your vac. Be careful not to damage any igniter or electrical items.
  • Clean the inside of the lint trap duct of sediment/ buildup
4. While you've got it open replace the drive belt and check the pulleys.
If this improves your dryer, hang onto it for a while longer! Most times dryers just need a good cleaning and the exhaust duct cleaned. If you're not satisfied with the results, take it to the curb and recycle it to another family.
on Dec 07, 2009 | Dryers
Gas will come on and heat for a few minutes and then go out
you either have bad gas coils if it heats for the first 15 to 30 minutes and then the flame doesn't lite any more or you need to clean out the dryer because there is a blocked vent line or duct stopping the air from moving through the dryer and then to the outside.you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and if the vent line is long i use a leaf blower to blow out the vent line.unplug the dryer when ever you're working on it
Jun 22, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer heat not going on. Vent is now
In duct area there is a thermo switch. 1/4"x2" white in color. two wires are connected to it. This goes bad from overheating due to dirty duct work. This stops dryer from firing to ignite gas. Replace and you should be good. You can check all other thermo switches with a tester. Some are silver and round some are what I stated.
Jun 06, 2010 | GE DCVH515GF Gas Dryer
Dryer won't heat? Lint screen is clean, duct is
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 12, 2010 | KitchenAid KEHS01P Electric Dryer
Dryer takes to long to dry
there is a lint build up either in the vent line or in the dryer,you should do a clean out on the dryer once a year so this doen't happen,unplug the dryer,go outside and make sure nothing is blocking the flapper,if it's clear go back inside and remove the vent line from the back of the dryer and blow it out if it's a long run,i use a leaf blower to do this,then remove the lint filter,if it's inside the dryer then you need to remove the front panel,take off the duct that the filter slides into and clean out the duct,also vac out the inside of dryer where the motor is,if the filter is on top take off the back wall and clean the duct there,you need to still vac the inside of the dryer,if it's a gas dryer you could have bad gas coils,they fail when they heat up,you'll need to check to see if the flame is lighting after 15 to 30 minutes,if it doesn't light change out the coils sitting on top of the gas valve,hope this helps
Feb 07, 2010 | Maytag Dryers
Kenmore dryer working fine was stoped while out of house on return would not start again 1995 model gas
the pilot lighting system may be clogged with lint. unplug cutoff gas behind dryer. remove exhaust duct and see if there is more than the thicknessof an inkpin. if it is then it is time for a serious cleaning,both in the rear panel and the vent. use no screwsin duct, use onlymetal tape to fasten the connector .use only the duct clamp too reconnectto dryer.make sure there are no crimps in duct. karl
Oct 29, 2009 | Kenmore 63942 Dryer
Dryer does not dry clothing well
CHECK AND CLEAN THE DUCT FROM THE DRYER TO WHERE IT LEAVES THE HOUSE A LOT OF FIRES START BECAUSE PEOPLE DON'T KEEP THE LINT CLEANED FROM THE DRYER ITSELF AND THE DUCT WORK THAT LEADS OUTSIDE. IS THIS UNIT GAS OR ELECTRIC
Aug 10, 2009 | Dryers
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
