Question about Sony PlayStation Portable (PSP) Console
God of war
How to get the god of war
to my psp
  • cjay_5488 Jan 16, 2009
    how can i get this into my psp
  • kentcanlas15 Apr 05, 2009
    how can i download god of war 3 into my psp?
Asa
Posted on Dec 06, 2008
Awdzdgrtwzds
Posted on Jan 22, 2009
  • casis Jan 22, 2009
    zasasdasasasdasdasd
Sdtsdfsdfsd
Posted on Jan 16, 2009
    Problem Solver:
  • 5 Answers
Depends.. Go and buy the UMD if you have official sony firmware or download the iso/cso if you have custom firmware
Posted on Oct 12, 2008
Kljgyhjogjhghjroihjriohjtrhoirtjgoitjgotipjhiohjytoihjtohjtohtjhthjtohjhohjoihjhotjhotgjthjthijtoihjtrg-´0hjt-´0ihtjhg0itjhtoihjtrohjtoihjthtjhitjh9yijht9hjtr9-hjtrohijthotjhthjthjtohjthojthoutrhoitjhrhujtr09hjtrh´0jtrhjohijthoijyhiojhoi´joighjtrhiojtrohjtotjhtrjyhotrjhtjhtohjtrhjtrhjtr´hotróhitjr
I dont know
4 Suggested Answers
  • 4 Answers
SOURCE: during my game play my psp freezes for hours
check and make sure there aren't any scratches on the umd that could cause a problem
Posted on Oct 27, 2008
Jmizpah777
  • 290 Answers
SOURCE: God of War 1 and 2(Unable to read disc)!
Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
probably your game console has problems on disk reading.
FIX Those Ps2 disk errors.
You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
well. i hope this works.
pm me if problems continue.
Posted on Aug 08, 2009
Dajuliehubby
  • 203 Answers
SOURCE: play staion 2 reads all games but wont read god of war 1 and 2
Best bet is to try a laser lens cleaner and seeing if that helps. I know it sounds silly that it might be dust on the lens when only THOSE games don't work, but stranger things have happened.
Posted on Jul 30, 2010
God of war psp freezing on my psp 2000
the problem was in you are game not in lap top have you tried another disk?
if you need the perfect games without any errors go to this website.
http://www.skidrowgames.net/
http://www.skidrowgames.com/
Apr 11, 2012 | Sony God of War: Ghost of Sparta for PSP
Does anyone know anything about the game god of war for psp
I found a brief description about God of War : psp games
here is the link : http://free-psp-games.info/psp%20games/action/god%20of%20war.html
Dec 03, 2011 | Sony PlayStation Portable (PSP) Console
Just want to ask want on what firmware will the game God of war: Ghost of sparta would work. my psp 2004 has a 5.50 gen B-full firmaware but the game does not work.
It should work on that firmware... However, try 5.50 GenD3.
be cautious though because this CFW SHOULD BE INSTALLED to PSP Slim with TA088v3 boards or higher. if you do it by mistake, your PSP will be permanently bricked.
May 14, 2011 | Sony God of War: Ghost of Sparta for PSP
How to download god of war ghost of sparta
To download God of War for your PSP click here and for second link please click here. With the help of these two links you can download any game you want. So, Enjoy your gaming :)
Thanks for using fixya.
Apr 29, 2011 | Sony God of War: Ghost of Sparta for PSP
How to download it free
I have the installer for Sony God of War: Ghost of Sparta 3000. Just provide me with your email address so I can send the file to you. Are you using a stable PSP? If not, I will also send you the necessary firmware and enabler for your PSP.
Jan 26, 2011 | Sony God of War: Ghost of Sparta 3000...
How to download god of war 2 on psp
God of war 2 is a playstation 2 title. The psp only plays psp and playstation 1 games.
Jul 24, 2010 | Sony PlayStation Portable (PSP) Console
Dive not working in god of war psp
just make sure you are using the right combinatio of buttons, check game controllers
Aug 05, 2009 | Sony God of War: Chains of Olympus for PSP
Download psp games
Unfortunately, you can't. God of War 3 is only playable on the PS3. Sorry.
Apr 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp god of war chains of olympus no menu selection..cant play
Take it to the store you purchased it from or to a game store and see if it works properly in another psp. If it works in another psp then you have a problem with your psp. If it doesn't work in another psp then you just have a bad umd.
Dec 26, 2008 | Sony God of War: Chains of Olympus for PSP
Sony PlayStation Portable (PSP) Console Logo
132 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
