Question about Mitsubishi WS-55511 55" Rear Projection Television
Tv won't come on
Mitsubishi tv won't come on with remote or power button on tv
  • unfolded Oct 19, 2008
    Where did you locate the repair kit and instructions? Do you have contact info or a weblink?
    thanks in advance
I found this bit helpful (look at my comments at end):
My Mitsubishi WS-55613 (55" rear-projection HDTV) died Saturday, just when I tried to turn on the UNC/Kentucky game. It was exhibiting what I'd seen described before (found at another online HDTV forum) as what appears to be a very frequent problem that occurs in Mitsubishi rear-projection widescreen HDTV's, referred to as "The Blinking Green light of Death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other, and you ain't got no TV to watch... tv won't come on - frown.gif
About a year ago, I'd noticed and saved an article describing this issue, along with a repair procedure to replace the four (apparently inadequate) 1000uF/16 volt power supply capacitors in the "DM module" (one of the two onboard microprocessors). These capacitors are apparently undersized, in that they will eventually fail (usually after about 3 years) if and inevitably when there are voltage fluctuations in the circuit above 16 volts. (If you Google: "Mitsubishi + Blinking Green Light of Death", it's amazing how many other Mitsubishi rear-projection TV owners have experienced this problem.) It is recommended to install either 1000uF/25 volt or 1000uF/35 volt capacitors as replacements, so that they will be more than ample to handle any voltage spikes that will occur.
Since I have little/no experience repairing printed circuit boards, I was a bit intimidated to try this on my own, but was motivated by the one person at that forum that said he'd had to pay $600+ for the replacement DM module his set needed, along with about $150 for installation.
I went online to another HDTV forum and this time found two similar "fix" articles describing the same problem and correction, and one of these articles came complete with photos depicting the repair procedure. This led me to believe that this might actually a legit repair, as others had posted that they'd successfully repaired their TV's w/this procedure. On Sat. night I went to Radio Shack, bought the (4) 1000uF/35 volt capacitors recommended as replacements (they were out of the 1000uF/25 volt caps), and after taking the back of the TV apart and removing the faulty DM module, got my girlfriend Rene to help hold the DM module's printed circuit board while I desoldered the old capacitors and installed the new ones. (She was a remarkably patient assistant, I might add...)
Much to my dismay, after getting the TV put back together enough (I thought) to test it at about 12:30 a.m. Sunday, it would still not work, and exhibited the same "Blinking Green Light of Death". I went to bed VERY disappointed... crying.gif
Sunday morning, I set about taking it BACK apart, to see if I'd done something wrong or left something disconnected. I then realized that since I'd not installed the back cover plate for the DM module, which has (apparently critical!) grounding straps essential to the proper functioning of the DM module - the DM was not getting proper grounding. error.gif My brother, (who is an electronics tech for a local LED lighting manufacturer) came over before I reassembled the TV and also found a couple of "solder bridges" on a couple of the DM's printed circuit board components (sloppy soldering), which he feels might have also contibuted to the failure of the original power supply capacitors. I put it all back together again, plugged it in, and it fired right up!
NOTE:
I went ahead and ordered a full kit online. Came with service manuals for the set and detailed pictures of how to do the repairs. Took me about 2 hours, but my Mitsubishi is up and running! contact:
servicemanuals13@gmail.com
Posted on Oct 10, 2008
4 Suggested Answers
SOURCE: mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
Posted on Nov 27, 2008
SOURCE: constant blinking green power light but doesn't turn
This is from my WS65907 service manual.
4. Self Diagnostics
The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
Posted on Apr 08, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2009
Only turns on with remote and won't stay on
Power button on the television itself may be stuck - go to the unit and press the power button se if it engages. If it depresses and sticks there is your issue - if it does not check the remote take out the batteries and unscrew the unit take the rubber pad out of the casing and spray out with canned air. If that doesn't do it - try unplug the tv from the wall for 1 minute or 2 and replug-in and see if the problem persist if so you will need to contact a tv repair shop but it sounds like the button on the tv needs to be cleaned because something is holding the power position in a spot to turn the unit off
Jan 14, 2013 | Mitsubishi WS-65411 65" Rear Projection...
When we push the power button on the remote or on the tv the green light comes on for one second and then shuts off ... tv won't turn on
you have a short circuit in the power supply.
1) test the power cord very well
2) test the main swithc for short or open
3)test the power supply, look for a short in transformer+coil+filter+diode+rectifier. and replace
4)test the HVRECT+fLYBACK+ horizontal output for +125Vdc +vertical output for +80Vdc ALL this go to the CRT
color +12vdc+other circuit +12vdc. The first thing do you will have is RASTER, see the block. d
God bless you
Jul 31, 2012 | Mitsubishi WS-65819 TV
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Remote
this is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Jun 06, 2007 | GE HO97685 Remote Control
Mitsubishi WS-55511 55" Rear Projection Television Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
