Question about Whirlpool Refrigerators
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
  • 958 Answers
Are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Posted on Oct 06, 2008
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
Water cooler stopped working
Compressor seized, may just need a new start relay or capacitor
Aug 07, 2012 | Haier WDNS32BW Hot Cold Water Cooler With...
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
Not dispensing cold water
turn the system of unplug and turn the machine upside down without the water bottle. There shud be 2 drain plugs underneath. remove one at a time and force water or air backwards thru these drains to ensure no obstacle in pipes. Also check inside that no pipes are bent closed so as to block water from flowing thru. It doesnt work via a pump but a simple gravity feed system. also the cooling works diferent to a normal fridge, doesnt have gas in it it cools by a heating element that cools on the one side and heats on the other side. Also check that ur fan on the cooling side is still running properly it shud turn of after a couple minutes and turn on when the water gets hot again.hope it helps.regards.viv
Dec 30, 2009 | Hamilton Beach Water Cooler with Storage...
Weird taste and smell in water from cooler
The best way to clean it is to run pipe cleaners through the tubes followed by a baking soda solution. If you have an empty cooler bottle put a gallon of hot water into it and three tablespoons of baking soda. Install it and run all of the water through the cooler and also through the hot side. This will make it clean and sweet smelling once again.
Oct 06, 2009 | Kitchen Appliances - Others
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Advise
you need to purge the air out of the "hot" side after placing the bottle on top. If not enough water is inside the chamber the water will boil.
Jul 07, 2008 | Hamilton Beach Water Cooler with Storage...
Substitute water refill..
I'm not sure what you're asking. You can run a plastic tube from a faucet head to the reservoir of this water machine - liable to get messy/wet if not handled properly. You can also puncture a hole in the water bottle - toward the bottom (careful) and tape a plastic tube from the water bottle to nowhere - be sure to tape the end shut so you don't experience leakage - will get annoying over tiem.
Just call the manufacturer/distributor - if they can't fix it or replace it under warranty, just buy a new one.
May 30, 2008 | Avanti Hot and Cold Water Cooler
Refrigerators Logo
423 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
