Question about Sony Ericsson W850i Cellular Phone
How the heck do i connect w580 to pc
I hook it with usb says"transfer files" then "do not disconnect until ?" but nothing ever happens.
  • Anonymous Oct 09, 2008
    i have the same problem! i cant find a solution for it ANYWHERE. help =[
  • idathecutest Oct 15, 2008
    i cant connect my phone to my pc. i use vista ultimate and i cannot install the phone software. can u help me on how can i install my w850i pcsuite?
    Brigadier General:
  • 7,752 Answers
Once you have connected the usb cable and the phone is on , you will see file transfer at this time you can select this file once the phone is in transfer mode you can do nothing and PLS do not disconnect the phone at this time it could damaged the phone.....
The computer will now try and install the drivers necessary to read the phone if you are using XP the pc will find them if you are using VISTA then you may need to update the driver online at the sony ericsson website.
Posted on Oct 21, 2008
How do i transfer music from my pc to my samsung gt19000
  • Turn on your computer. Connect your Samsung MP3 player to your PC via the USB cord. Power on your Samsung MP3 Player.
    Click on "Open folder to view files" when it pops up or click on my computer and select the Samsung "drive."
  • Transfer music. A folder will appear containing all music files on your Samsung Player. Click and drag any music files from your computer to this folder to add them to your MP3 player.
  • Wait until the transfer is finished to disconnect your Samsung MP3 Player.
Apr 06, 2011 | Audio Players & Recorders
When I plug cable from camera to USB computer connection, nothing happens!
Not enough information. The transferring of files requires a sequence of functions to happen before the pictures will transfer to the computer. You will need the camera software installed on the computer. The camera sequence for transfer and each camera is different, some just need you to turn the camera on after connecting the USB cable while others require you press the "Playback" button to transfer files. Depending on the camera software installed on a computer they "normally" download to a file folder then the pictures can be opened in the software programing.
Feb 08, 2011 | Cameras
How can i connect and transfer photos and other files from my samsung mobile phone gt-s3370 to pc? i have not received any cd with set or any other software.nothing happens when i connect the phone to pc...
Download first a PC Suite software in your computer. This software will let you access the system of your phone. In this software you can transfer files, videos, audios to your phone from computer and vice-versa.
Download this software from this site
http://www.rapidse.net/samsung-gt-s3370-pc-suite-free-rapidshare-search.html
Once the software is installed in your computer, run it.. connect your phone via usb data cable...search your phone by connection and Connect.
Good luck.
Please rate. thanks
Aug 14, 2010 | Computers & Internet
When i connectting to computer nothing is happen
this is a common problem with the config files. to correct you must:
1. with player powered off hold menu button and connect to PC
2. hold menu button until a blue screen appears
3. windows should find your device and think it's a USB mass storage device
4. when Auto play asks you what you would like to do, select "Open folder to view files.
5. Find the "CONFIG" folder on the device, and delete everything in it.
6. disconnect, and then reconnect your device....
wham-o...it now works
Aug 05, 2009 | Philips GOGEAR SA6045 MP3 Player
Hook samsung to pc
before you connect cell to pc. change the (cell) connection settings to either usb/bluetooth. now connect.
go to my computer and you cell icon or harddrive should have appeared. and you be able to continue using studio 3.
May 21, 2009 | Samsung SCH-R400 Cellular Phone
Hook up to usb port, nothing happens
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Mar 24, 2009 | Nikon COOLPIX L18 Digital Camera
Photos not transferring
Please try deleting the drivers , then reloading.
It will look for the connection again, and hopefully find it this time.
Jun 20, 2008 | Nikon COOLPIX L10 Digital Camera
Music download from PC to Phone via USB!
Hi, u should install the software provided in the LG CD itself. Once installed. activate the software pc suite. and also connect your LG phone via usb cable. You shouls see and indicated as connection ready. Select the option 'Content' under Tool, and u should able to carry out file transfer from there as usual way.
May 01, 2008 | LG KU990 Viewty
Downloading pictures from phone to computer
When you connect the usb to the pc.....the phone should be asking if to do "transfer pictures".
select transfer pictures and a folder will be on you pc....select that
Apr 01, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Unable to hook up
if it's a fairly old pc some motherboards cannot supply enough power to the usb port to power the ipod especially if it's not USB2.0. Try other USB ports and leave other USB peripherals out so as to allow more voltage to the port you are using. Failing that you will need to purchase a mains powered USB hub, which should connect to the ipod no problem.
Sep 06, 2007 | Apple iPod nano
Sony Ericsson W850i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
