We have a Sony 1996 46" model KP-46S25 rear projection TV that just turned off and will not turn on. There is no audio or video. Is it time to place it curbside or is it a matter of replacing 1-3 projector bulbs?
    Genius:
  • 1,550 Answers
You need to replace the bulb .
Posted on Oct 06, 2008
KP-46S25.... PICTURE GOES OUT FOR A LONG TIME. FINALLY, PICTURE NO LONG COME ON. I HAVE SOUND.
Video output section has the fault. Check all the components on the video output section, which can be located at the picture tube base card.
Apr 29, 2012 | Sony KP-46S25 TV
Help Fixing SONY KP 46S17 Rear Projection TV
#1. is the ground witch the connector can be found most likely from the crt tube ground, the one that clip with return spring.
#2. is the flyback screen voltage can be found from flyback transformer most common color is red and be insert to the hole.
Oct 17, 2009 | Sony KP-46S25 TV
Sony 65
Type in toolbar Understanding Sony Blinking Codes this will take you to Sony post telling what is wrong with TV depending on how many Blinks.
Sep 18, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
My Sony KP-46S25 TV is blinking red light and is not turning on, please advise.
Please update this with the blink count. The standby light shouldbe blinking a repeated count with a pause. This will indicate the problem circuit and allow me to provide you with the probable defective part(s).
Thanks,
Dan
Jan 07, 2009 | Sony KP-46S25 TV
Sony KP-46S25
You have to find the reason why the fuse is blowing. to do that you have to open the up the TV anyway. try another fuse and see if it burns. fuses blow because there is more current going through it than the fuse amperage can hold. it is probably a burnt resistor.
Nov 28, 2008 | Sony KP-46S25 TV
Sony tv kp-46s25
how many times does the light flash cause it might be an error code from the shut down circuit
Apr 12, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Television
If model # is KP-46S25, red CRT is probably bad...have it checked by a qualified Sony tech......................T.
Jan 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Televison & Video Logo
Top Televison & Video Experts
