Question about Aspire Digital AD-900 DVD Player
ASPIRE DVD Progreesive Scan AD-N8208
My DVD player will not load discs~ I changed the battery in the remote which is operating perfectly. The blue title "AD Digtial DVD..."" screen appears when I turn the machine on but there is where the action stops... HELP Please!
  • emilyduden Oct 06, 2008
    My DVD player will not load discs~ I changed the battery in the remote which is operating perfectly. The blue title "AD Digtial DVD..."" screen appears when I turn the machine on but there is where the action stops... Machine is very clean. I have tried to load a CD Laser Lens Cleaner disk as well, however, it would not load either.
    My DVD player will not load discs~ I changed the battery in the remote which is operating perfectly. The blue title "AD Digtial DVD..."" screen appears when I turn the machine on but there is where the action stops... Machine is very clean. I have tried to load a CD Laser Lens Cleaner disk as well, however, it would not load either.I have unplugged the machine and let it "rest"to reset itself, this has not solved the problem.
    President:
  • 2,712 Answers
Its most likely one of three causes:
1. Dirty lens - Use a lens cleaner disk.
2. Scratched lens or failed optical assembly - The optical assembly will have to replaced. If this is the case, it would be cheaper to simply buy a new DVD player, as parts and repair costs would be too high to justify a repair.
3. Failed motor - This is preventing the disk from spinning, and hence cannot be read. This is a cheaper fix, but would still need to be taken to a service center for repairs.
Hope that helps!
Posted on Oct 06, 2008
  • 1,800 Answers
HI
You can download the owners/users manual from the Panasonic website. But you do need the model number.
It is not unusual for dvd players to quit reading. It is caused by either the laser diode in the optical pickup assembly or the digital decoder circuits becoming defective. Either repair is more costly than just buying a new dvd player.
Does it still play CDs okey? If so, that could mean the internal electronics is okey but the laser optics are not working satisfactory for dvd. The laser beam must be much stronger for reading a dvd disc compared with a music CD disc, for example. And this could mean the laser diode has become weak and will read music CDs, but not dvds. The cost of replacing the laser diode is about $100! You can buy a new dvd player for $28 and up.
  • 6,487 Answers
Try doing this steps:
From the remote control:
SETUP
Scroll left or right to the PREFERNCES menu.
Scroll down to the bottom until DEFAULT is highlighted.
Hit the PLAY button in the remote while RESTORE or RESET is highlighted.
The DVD player was reset back to factory settings within 10 seconds.
If still not wrking after that the lens of this player may be bad already and needs a replacement...
    Genius:
  • 1,148 Answers
Also try this , it has worked a thousand times ,,your lens could be dirty,, try using a dvd lens cleaner,, if that doesnt work blow it out , try using a air compresser,works good ,,trick that has worked a # of times for me,, good luck
    Scholar:
  • 155 Answers
Have you tried resetting the power? Unplug the power cord. Hold down the power button for 10seconds. Then try it again.
    Scholar:
  • 116 Answers
The lens which reads the dvd must have gone faulty.
  • 6 more comments
  • mastermind10 Oct 06, 2008
    try to clean the area where you place the dvd disk.
    also try another dvd in the same device.if the same problem then try the same dvd in the another device if you can arrange one to check .that will give u a better idea at where the problem lies.
    check whether you get any noise of dvd spinning in the device or not .if you r not getting any spinning noise when you insert thr dvd that means the motor which spins the dvd is gone faulty.you have to get it replaced.and if it spins then you can indicate that the problem is with the lens.try cleaning the lens.
    if still does not weork then its the problem of dust particles setteled on the lens internally which cannot be cleaned without opening the device.and for that taking it to the service center is a better option.asd they will service the whole device properly and technically .to make it proper.
    this is a common problem faced by many clients and gets solved after servicing and cleaning.
    for any further queries please reply.
    that only i m explaning you my friend that the lens is not able to read the disc which you load.and so you r getting this problem.and about the cleaning cd you inserted that only cleans the device if the dust particles setteled in the upper area where you load the disc, that cannot clean the device internall.that should be done manually.
    what i want to explain is the lens is the eye of the device which reads the disc if any dust setteled on the eye how can the device read the disc.and so it is not loading the disc.for example if you close the eyes how can you read any thing.in the same way the thin glass lens in the device should be clean and not blocked by any dust particles.
    keep updated for further queries.
Remote code
yes you need to read the manual
Dec 31, 2011 | Aspire Digital AD-1000 DVD Player
DVD player main page is no longer colored (blue)
please enable NTSC. your settings is in PAL. its due to your system PALSECAM.
Aug 14, 2009 | Aspire Digital AD-900 DVD Player
Dvd player won't read the dvd and displaying'no disc'
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 26, 2008 | Philips DVP5140 DVD Player
My DVD player does not seem to be able to read disks. The loading screen comes up and then it will say no disc.
Apr 23, 2008 | Televison & Video
Disc is not being read,not spinning
Apr 21, 2008 | Televison & Video
Player indicating no disc loaded.
Apr 16, 2008 | Televison & Video
Remote Codes
Have you tried using codebases for other companies? It isn't uncommon for a company to re-brand another's hardware.
Nov 24, 2007 | Aspire Digital AD-1000 DVD Player
Aspire Digital AD-N820B DVD-R stuck in Progressive Scan ( PSCAN )
I just had the same problem with the same model but I was able to figure it out after a while.
SETUP
HIt the PLAY button in the remote while RESTORE or RESET is highlighted.
Oct 11, 2007 | Aspire Digital AD-900 DVD Player
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Aspire Digital AD-900 DVD Player Logo
225 people viewed this question
Top Aspire Digital Televison & Video Experts
Josh Whitehead
Josh Whitehead
Demonic-2011
Demonic-2011
Are you an Aspire Digital Televison and Video Expert? Answer questions, earn points and help others
