Question about Minolta C350 Color Printer/Scanner/Copier
Badge labels how do I print a 3" X 12" label sheet for badges
  • 145 Answers
Do you user manual? its in there
you can navigate by selecting bypass try first,select label printing
machine and printer setting must be the same,
hope that help
Posted on Oct 06, 2008
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
Tip
Remove Motorcycle Tank Badge
Removing the "badge" (also referred to as the nameplate or label) from your motorcycle tank is very easy. No tools are required!
Did you know that badges are kept in place with adhesive? From start to finish the whole process will take less than half and hour.
The required "tools" are a hair dryer, dental floss or fishing line, adhesive solvent, some gloves, and a soft cloth or towel.tools.jpg
Turn on the hair dryer to the highest heat setting available. Either hold it yourself, or hang it upside down by the cord from your handlebar, leaving the hot air blowing on the badge for about ten minutes. Next, saw beneath the badge with dental floss or fishing line.flossing.jpg
Using a gentle sawing motion, continue all the way behind the badge.fishingline.jpg
Removing the residual adhesive is the most time consuming part of the project.badgegone.jpg
I recommend using Goo Gone or another adhesive solvent. It won't ruin your paint, but will weaken the adhesive. Use more solvent than you think will be necessary. The more the better. googone.jpg
Wipe with a clean, dry cloth and you're done! The final result looks great. Your tank is now ready for custom graphics or paint. finished.jpg
on Mar 16, 2009 | 1999 Honda F6 C Valkyrie
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
I have an HP Laser Jet 2100 and am having problems printing the Avery 5895 Name Badges. The badges have a new design which allows them to pop off the page way too easy and when they are in the printer,...
One has to assume that you are using the manual feed tray (tray 1) to print the labels.
Give Avery a call and let them know what's happening.
In the meantime start using compatible labels from another manufacturer.
Just a thought....you didn't say where the labels are being pulled off the sheet.
If it is at the fuser you can use the rear output bin which gives a straight path thru the printer.
Feb 17, 2011 | HP Office Equipment & Supplies
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
How to do filtration in gmail, I remember you can set badges also. any idea?
Hello and Welcome to FixYa!
Please follow these steps to get a filter;
  • Login to Gmail
  • Click Settings ( From top right Corner )
  • Click Filters
  • Click Create a new Filter
  • You will asked about filtration criteria ( Like From clause, TO clause or Subject clause )
  • When done, click Next Step
  • There you will asked about the Response ( What to do?, Push it to inbox, mark as read...)
  • Here you can also mark as Label to it, create a label here (This is for the badge you asked about)
  • Click Create Filter.
  • Now come back to Gmail Home.
  • Yo will see that just created label on the left hand side.
  • Before the label there will be a small box, click it to choose a color badge.
  • Done.
If you are still having any issues, do ask me.
Thank you for using FixYa!
Concerned, Nooh
Aug 17, 2010 | Google Gmail
When printing from a Zebra TLP 2844, text is getting cut off. I am printing from internet software, center aligned. If there are too many characters, the text is getting cutoff on either side (I would say...
Check the drivers you are using, try downloading drivers from Nice Label or Segull Scientific. Setup the page size to fit all the text, use a ruler to measure the lables.
Apr 27, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Ink smearing
This is a compatible ribbon/label combination as Zebra says. The only thing you can try is to turn up the darkness setting. The 5586 ribbon you are using requires a fairly high darkness setting ~ maybe around 25. If this still doesn't work then the best solution would be to use a Zebra card printer that prints right on the plastic card. These are made for exactly what you are trying to do. If you don't want to buy the printer then we can print them for you when you need them. I can give you my email if you want us to help.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Problems when replacing defective zebra with another
Here's a manual if you don't already have one:
http://tinyurl.com/yb2rpd4
Loosen the plastic thumbscrews that tighten the printhead down onto the ribbon and media. Perhaps there's too much pressure, not allowing the media to advance.
Also just try to reset it to the factory defaults.
Hold down FEED and PAUSE while you power up. When it's finished resetting, press MODE 4 times to save the settings. I've had to do this quite often with ours.
Good luck! I hope this helps. If so, please leave a rating!
Jun 17, 2009 | Zebra Stripe S600 Thermal Label Printer
52 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
