Older model sharp tv G1018CESA large solid black rectangle on top of picture dont know how to get rid of? if i change channels can see full picture but rectangle pops up in seconds
  • Anonymous Dec 11, 2008
    older model tv by sharp tv.vcr combination. the television keep going off .
    Scholar:
  • 142 Answers
Go into the menu and turn off closed captioning. You have accidentally turned it on to text or cc1 or cc2, but that is positively what is wrong. Good Luck! Please rate this solution!! Thank you,
barneyluc
Posted on Oct 06, 2008
I have a sharp model LCD-32le451u, version cl485090 revision 1011. I tried reset all settings. It keeps displaying "please scan channels". I did and please scan channels stays. How do i get rid of it
some older tv's will not pick up any channels on digital cable. I changed cable company's and on of my tv did not pick up anything after that.
Oct 05, 2017 | Sharp Televison & Video
I just changed from Comcast Cable to Verizon Fios. Since the change I am unable to get a full picture on Fox News. There is a narrow horizontal picture with 1-2" black bands across the top and...
This is a function of your set-top box (STB), and has nothing to do with the TV. I know several FiOS users with the same trouble, and it's annoying but there isn't anything you can do to "fix" it. What is really strange is that the screen size can change even on the same channel, depending on the particular program being broadcast. It has to do with the aspect ratio of the programming from the provider.
Jan 12, 2011 | Panasonic CT-32G23 32" TV
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
May 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Is closed caption turned on? (and the channel doesn't have any captions) Turn it off.
Mar 27, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
On my Sharp LCD TV a black empty box appears
You will need to find the close caption feature in the menu adjustments and turn it OFF. You should do it for all the individual channels that have it activated.
Aug 20, 2008 | Astar LTV-20SD 20 in. EDTV-Ready LCD...
Large Black rectangle on bottom half of screen
My mother-in-law had this problem on a Quasar for two years before she finally mentioned it. The rectangle is a text box for closed captioning or for a demonstation list of features, but without the text. I restored the factory presets and poof... problem solved.
Look in the manual and find how to restore the factory settings - it will probably be some weird combination of buttons that you would never guess. On her set, which has a built-in VCR, it was simultaneously pressing "play" and "FF" (on the set, not the remote) for five seconds until the set powered down. Yours will probably be something different but equally odd. That should get rid of the black rectangle. Then you go through the initial setup and you're back in business.
Jun 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Sharp Aquos LC-46D64U Large black rectangle in lower half of screen
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
Jan 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Jan 10, 2008 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
