Question about Refrigerators
I have a GE GSS25JEMACC and compressor doesn't kick in... all fans run. Yesterday the defrost cycle thawed the entire freezer full of food. Took back panel off inside freezer, there was no frost or ice anywhere. Could defrost cycle be stuck on?
  • 943 Answers
Hi thanks for the question. if all fans are on . not in defrost cycle. look at the compressor relay. replace the relay. thanks the appliance doc
Posted on Oct 06, 2008
All my food thawed in my freezer. Is it just defrosting or is it broken?
Most newer freezers have self defrosting. But it will not thaw out the food at all. For it to thaw completely in 1 day, the compressor did not come on at all. I would first check the fuse or circuit breaker in your home. Many different issues could cause the same result of the freezer not getting cold at all. Defective thermostat, defective compressor, refrigerant leak or loose wiring at connection points. It could possibly be stuck in the defrost mode too.
Oct 30, 2015 | Refrigerators
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
Fridge is not cold and freezer is thawing all my frozen food , is compressor gone?
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
Nov 17, 2011 | GE Refrigerators
I have a Frigidaire Model FRT18s6aws year model 06. It will thaw an d refreeze food and ice on and off. When it thaws it seems the fan is working fine and is triing to get cold and the next day everything...
When your unit thaws - do you hear the compressor kicking on at the start of a cycle? If not, maybe the compressor relay it hanging up somehow. Or the compessor capacitor is malfunctioning. It is NOT a compressor problem though.
If you are capable of getting to the defrost heater circuit, you should check the defrost thermostat and timer (if there is not ice build up behind the panel. If the defrost circuit is active too long it could cause that condition - but you defrost heater is not the problem unless there is an ice build up.
Jun 12, 2011 | Frigidaire FRT18S6AW Top Freezer...
I have a GE model GSS22JERFWW S/N AL243114.The freezer portion doesn't freeze the ice trays and the refrigerator portion doesnt keep anything cold as it should even tuned up to 9 whereas it used to...
Things to check: does the compressor run? Does the fan close to the compressor run? Does the inside fan run? Is the rear wall inside the freezer covered with frost? That would indicate that it is not going into defrost which will have the same result (no air movement). Does this help?
May 20, 2011 | GE Refrigerators
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
