Question about Sea Worthy 9001G Marine Casseiver AM/FM/Cassette Stereo by SEAWORTHY
Sea worthy marine cd player sea 2300 + esp
I would like to put a rubber antenna on it but it has one off those antenna with a wire.Does that kind off antenna just pull out?Not sure I started to pull it out but it seamed like it was hook in side?????
Need help finding parts for a marine radio I bought at a rummage sale, It is a Sea Worthy,Sea9504 AM/FM cd player. Just have the radio,need wiring harness, and a antenna .Don't know what else i need? Don't want to buy another one. Have speakers to. Besides E-Bay taking a chance that the parts might work. Went to sites on the internet.Do you know where i can get these parts cheap,If you could help me.looking to purchurse by check not by credit card.
Posted on Mar 02, 2011
Can't get FM to work on my Seaworthy 2300 Marine radio. CD works fine.
is the unit new? do you know how your FM antenna is wired. are you trying to pickup signal 50 miles offshore? Do you get AM?
Aug 26, 2016 | Car Audio & Video
My Jensen MCD 5110 Marine radio acts like the antenna is unplugged. I can't figure out how to remove the radio from it's sleeve to re-plug the antenna jack (if that is the problem)
I don't know much about marine radios. I am a ham radio operator, but they are much the same, if you do not hear any static (with squelch control turned down), then I suspect you are correct about the antenna. It could be the antenna itself, or the coax line to it, or the connection point at the radio or at the antenna. You're stuck without being able to remove it. If you do and find nothing at the radio, you'll need to check the connection at the antenna etc. Good luck.
Nov 21, 2014 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Why does the yellow wire for the radio on my 2006 185 sea ray sport have no power
The yellow wire should have permanent power for the memory. Check the inline fuse.
Aug 04, 2014 | Clarion M255 AM/FM Marine CD Player
SEA2300 +ESP - cd disc stuck in player
disconnect the power and open the side where the cd motor is and remove manually
Jun 20, 2009 | Sea Worthy 9001G Marine Casseiver...
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
No power seaworthy marine amp 400
Do you have anything plugged into the "REM +" slot on the power side of the amp? You need either a signal from a Stereo head unit or another power source to get the amp to actually turn on. If you are using a switched setup for the amp, you can make a little jumper from the Batt+ to the REM+. It doesn;t draw anything significant, it just needs power to signal the amp to turn on. If you aren;t using a headunit, make sure that you wire in a switch inline between ther power source and the REM+ port on the amp, otherwise, the amp will be on all the time.
Mar 30, 2009 | Sea Worthy SEA / AMP 400 Car Audio...
Memory not working
blue yellow to yellow and gray to red should be right
Feb 01, 2009 | Pioneer DEH-2300 CD Player
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
May 16, 2008 | Jeep Radios: Genuine 6 Disc Cd Changer
Car Audio & Video Logo
1,370 people viewed this question
Top Sea Worthy Car Audio & Video Experts
xxxxxx xxx
Are you a Sea Worthy Car Audio and Video Expert? Answer questions, earn points and help others
