Question about Smeg WD16BA Front Load Washer / Dryer
Burning (electrical) smell and other symptoms...
Dear Tresilla,
Many thanks for your help. Let me give you a quick update:
The suppressor seems fine, do you think it is worth changing it and see what happens? Please note the following:
Does a faulty suppressor explain 1) the motor 'clicking' sound (which may be normal, for all I know), 2) the burning smell (which seems to come from below - the motor or something), 3) the burned neon light, and 4) the apparently non-functioning dryer unit (which seems to heat up a little when I start the machine in drying-only mode, but the drum won't revolve at all)...? What do you think?
Could all these symptoms arise from the machine not being properly powered due to a faulty suppressor?
Let me repeat that I really appreciate your assistance on this. Should I manage to fix this, beers on me!!!!
Look forward to hearing from you
A
    President:
  • 1,462 Answers
Suppressor very unlikely to be the source of problems and would not explain the motor clicking
i think the main problem may be a faulty motor.remove the electrical connection and take the motor out - just held in by bolts - and examine carefully the motor commutator - the segments of copper the brushes run on.
i think you may find one or more segments lifted which would explain the clicking noise and maybe the burning smell. it would also explain the lack of motor rotation - just coincidence it happened on dry.
Posted on Oct 06, 2008
My tredmill works but after few mins I get burnt smell?
Treadmills are relatively simple machines, which means a burning smell can be quickly determined.
Check your treadmill belt for wear. Try to find where on the treadmill feels hot when you smell the burning. It could possibly be the electric motor or wiring giving out under load.
Oct 01, 2015 | Cars & Trucks
Bosch angle grinder
Replace capacitor, Yes it would give those symptoms
Feb 03, 2015 | Bosch Saws
Whirlpool over microwave combo has burning smell in microwave
Probably fragments of food burning on the waveguide cover.
Jul 31, 2017 | Microwave Ovens
Smell burning insulation. the connection in the unite that the power comes into that is the junction for the various other electrical lines inside the unite gets very hot and seems to be the problem. is...
Turn the power off and make sure all connections are tight. How do you know it's getting very hot? Are you touching it? Is this an actual terminal block or a breaker or is it inside wire nuts? Are you able to check amps AND are you heating or cooling??? Thanks
Aug 19, 2017 | Fahrenheat F2543 Baseboard Heater
We purchased this product a month ago and it seems to be giving off a burning type of smell which we can smell both outside the vent and in the dryer itself. it seems to work fine
If it smells like an oily burn then it is just the oil burning off of the new parts in dryer, this is common. If it smells like electrical burning then call the manufacturer for repair. Could be a wire burning and if it is new it is covered under warranty.
Jun 14, 2010 | Whirlpool WED5800S Electric Dryer
I have a Ruud Acheiver 90, I'm having some problems, the rollout (burner) limit switches are opening, and there is an electrical burning smell. It seems that sometimes the squirrel cage isn't kicking on,...
Thanks for your question,
yup your fan motor is bad, if you need to manually start it each time then the motor winding are bad and it is not getting the air across the coils, which in turn are over heating, thus causing a burning smell, and then tripping your limits, you need to replace this motor ASAP, before it does cause a fire, if the limits ever fail !! I hope this was helpful for ya, if it was please give this a rating, thanks again,
mr.grzz
Jan 23, 2009 | Heating & Cooling
Ruud Problems
ive seen this this year several times. first off take the combustion blowe loose from the ducting and look inside to see if theres any thing causing the blower to not run (water) what happens is that the flue gasses condense and run back into the blower then when it trys to start its binded.let me know if this does not solver the problem and we can get more into the furnance.
Jan 23, 2009 | LG LW1200ER Air Conditioner
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Burning smell (electric), continued...
in the second picture, the part shown is the suppressor - looks ok as far as i can see and if it is faulty, the damage is usually obvious.
suggesting the suppressor was an educated guess - if machine works ok then just soldier on. the other thought i had was the neon itself burnt out and this will not affect the working of the machine
Oct 03, 2008 | Smeg WD16BA Front Load Washer / Dryer
Burning smell (electrical) from my washing machine
possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
other possibility is the neon burnt out
Smeg WD16BA Front Load Washer / Dryer Logo
299 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
