Question about Pioneer DEH-P7700MP CD Player
Right rear speaker not working
Hello all. I've recently installed the deh p7700mp unit in my truck. I have the wiring harness connected and have installed several stereos in the past. For some unknown reason tho the right rear speaker doesn't work. No distortion or anything. Was wondering what this could be and if there is any way to fix this problem? Thanks for the help
  • 92 Answers
Start by connecting it to one of the other outputs off the deck, say the left rear. If it still doesn't work, remove the speaker and connect it directly to the head unit. If it works, then it's the speaker wire, if it doesn't, it's the speaker.
If there are amplifiers installed, switch RCA cables left for right etc. and see if the problem moves with the cable switch, try the same with the speaker connections at the amp. This will narrow down whether it's the amp or the RCA cable etc.
Car audio problems can be handled by a process of elimination! Eliminate what it's not and you're pointed directly to what it is.
Posted on Oct 06, 2008
How to get rear speaker signal from aftermarket stereo
You can fade front to rear in the menu but its not switched it might be fully faded to the front
Aug 31, 2014 | Pioneer Deh-X6600bt Car Cd Receiver...
Wireing diagram for a 03 gmc sierra pickup for a pioneer DEH-1200MP stereo please
Hello my name is Israel and I will help you. The following information will help you out. Please rate. Good Luck.
Feb 28, 2011 | Pioneer Car Audio & Video
Auxiliary too quiet when using my iPod!
clean all conects with acohol and cheak for shorts
Jul 08, 2010 | Pioneer DEH-P7700MP CD Player
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Sep 09, 2009 | Car Audio & Video
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Hello clarky909,
On your Alero, the 12V constant wire is ORANGE and should connect to the YELLOW wire coming from the DEH-2300 wiring harness. 12V switched on your Alero is YELLOW and should be connected to RED coming from the DEH-2300.
Hope this helps.
Jun 01, 2009 | Pioneer DEH-2300 CD Player
Purchased a jeep with pioneer dehp6600 receiver.
Remove the speakers and trace the signal pairs (wires) to their origin, maybe they are still factory harnessed where you can access a connection point behind the head unit. Here are the factory color codes .
Hope this helps
JEEP up_arrow.gif P o w e r Memory (+12v Constant) Pink Ignition (+12v Switched) Violet/White Ground (-) Black Illumination Orange Dimmer Blue/White Power Antenna
S p e a k e r s Right Front (+) White Right Front (-) Black Left Front (+) Green Left Front (-) Black/Yellow Right Rear (+) White/Black Right Rear (-) Brown Left Rear (+) Green/White Left Rear (-) Brown/White
Mar 29, 2009 | Pioneer DEH-P6600 CD Player
Pioneer Deh-2300
The wiring colors are the same on all major brands of head units it goes a following:
Red: swtiched +12
Yellow: constant +12
Black: ground
Orange/white: dimmer
Yellow/black: cell phone mute
Blue/white: amp turn-on
White:FL speaker +
White/black:FL speaker -
Gray: FR speaker +
Gray/black:FR speaker -
Green: RL speaker +
Green/black: RL speaker -
Violet: RR speaker +
Violet/black: RR speaker -
I hope I could help. Good luck
-Andrew Hawkins
Sep 12, 2008 | Pioneer DEH-P4100
Pioneer DEH-P7700MP
hey, either the face plate isn't getting good connection with the unit so you need to clean the connection gold plates or your just on a blank screen and you can fix that by pressing the knob in until the screen says Entertainment, then scroll thru the possible screens until you choose one you like.
Jun 10, 2007 | Pioneer DEH-P7700MP CD Player
Pioneer car radio DEH-P7700MP
Did you check the fuse with a ohmmeter. fuses that small are realy hard to see... just check the continuity between the two termanils on the fuse, there should be continuity. Check your fuse panel of your car or truck, maybe it poped a fuse there. Physically check the power input with a votimeter and see if you have your 12 volts to the unit.
Mar 24, 2007 | Pioneer DEH-P7700MP CD Player
Pioneer DEH-P7700MP CD Player Logo
118 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
