Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Wireless internet switch above the keyboard, right below the screen will not light up to indicate it's working properly. Cannot connect to the internet. How can I tell if the switch is faulty or if it's the wireless card? Any suggestions? Thanks...
  • dlblanch Feb 20, 2009
    Hi, just wanted to say after all these months that mspcrepair's posting turned out to be the most accurate as far as the original problem. Sorry I took so long in posting this. Several crises happened over these months to combine with the holidays to make things very hectic. Anyway, I was just googling stuff and realized I had never posted an update. It was a driver problem all along and my wireless switch works very nicely. I have internet--everything works fine! Thanks to those who posted helpful comments...much appreciated!
    Novelist:
  • 169 Answers
First, make sure that the drivers are properly installed and that there is no "splats" or exclamation marks in device manager for your wifi device.
If the drivers are properly installed, you should have an extra "network" icon in your system tray (by your clock). If so, you should be able to right-click on it and view network connections. It will pull up a window where both your LAN (wired) and wifi connections are. If you see your wifi listed, right-click on it and you should be able to enable it, thereby activating your light and your wireless.
If you don't have any of the above ....you need to re-download the drivers for your wifi and reinstall. That should fix you up :)
Hope this helps - remember to rate :)
Scott
Posted on Oct 06, 2008
  • 4 Answers
There is another option also. I have a HP zd7000 and the wireless button hase never been able to work. this is because the circuitry for the wireless is placed on a daughterboard within the chassis. my zd7000 does not have this daughterboard so the wireless button is actually useless (thats what you get for buying second hand lol)
if you have to check this, it will require technical knoweledge (if you are not sure about taking a laptop apart I would strongly suggest you don't as you may do more harm than good)
so the question is... has the wireless button worked in the past/does wireless hardware show in device manager?
answer yes = reinstall drivers, if this doesn't work and you have the skills check the daughterboard is secure and not loose.
answer no again if you have the skills check that the daughterboars is a) THERE, and b) not loose before installing drivers.
in the evnt that there is no daughterboard, you can do what I did (get a PCMCIA wireless card) it doesn't make the wifi button work, but it does give me internet
Posted on Oct 08, 2008
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
Feb 24, 2013 | Computers & Internet
Will not connect to the internet. It just started this. It tells me there is no internet, when I try and fix the problem the computer tells me I need to turn on the wireless capabiltiy. It tells me it...
It's been a long time since I've seen this model, but with Acer's I remember the button generally being either near the power button (would be a button with an LED light behind it) or as a little switch on the front, lower side (basically under the touchpad)
The button itself will have an icon that looks like a radio tower with little' ) ) )' coming off of it in in different sizes. If you don't see it, look at the F keys for the same symbol, then use the Fn button and press that key. I know you said you looked everywhere but hopefully this helps.
Sometimes there is a software switch also that will allow you to turn on / off the wireless, verify that when you try and connect to a wireless it doesn't ask if you want the computer to flip the switch for you.
Mar 17, 2011 | Acer Aspire 5500 5570-2609 Laptop
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
Can't Turn On WiFi
Hi Theresa
Try this.
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire
5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa
2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
If this will still not turn the switch on, try to go to the network connection / network and sharing center. right click on wirless network connection and click diagnose,
then it will prompt you to turn on the switch. Just click on "turn switch on" then windows will ne the one who will on the wireless switch.
Sep 17, 2010 | Acer Computers & Internet
Wireless switch
Here is all I know about Compaq Presario wireless switches. Sorry, but w/o a model I can't be more specific.
Compaq Presario, Model not specified - Button on the Back
C304NR - Button on upper right above keyboard deck, Blue is enabled
CQ Series - Button above the keyboard (antenna icon on button) next to power.
** CQ50-107NR (Conflicting reports on this model show:
Button above keyboard (antenna icon on button) next to power or lighted button below space bar that turns the touch pad on/off.
M2000 - Button above the keyboard (antenna icon on button)
Dec 11, 2008 | Computers & Internet
Connecting my wii to the internet
to connect your wii to the internet connect to the following link or read the following instructions
http://systemsetup.nintendo.com.au/Connecting_Online
to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
a computer connected to broadband internet
a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
your wii console to be nearby all of the above
If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
if you are using a wireless connection follow steps below.
Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
On the next screen, select 'wii settings'
In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
Select 'connection settings'
select an open connection indicated by 'none'
select the corresponding option, Wired or Wireless connection
Wired:
Wireless:
Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
the wii will search for an access point, select the access point you wish to connect to, and save the settings
The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
hope i helped!!
Sep 19, 2008 | Video Game Consoles & Games
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
716 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
