Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE gas stove
I have a GE gas stove with oven problem. It will not heat food evenly and it seems that heat is escaping (almost feels like it is blowing) from the area right underneath the digital controls on the top of the stove. I don't know if this escaping heat is related but never noticed it before. Also before you could set the oven to the exact time stated on food cooking directions and it would come out perfect.. Now you have to cook extra time and food is not cooking evenly. Help!!!
    President:
  • GE Master
  • 2,651 Answers
Sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Posted on Oct 07, 2008
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Not heating food. Everything else seems to operate as usual. No unusual sounds. GM over the stove unit. # years old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
llllllll;
Oct 18, 2010 | General Electric Microwave Oven
GE JBP90 Gas Range is not holding heat very well in the oven. Takes ages to heat up to cook a pizza. When oven is on, heat pours out from under the control panel. I suspect mice have messed up the...
Your posted model is for an electric stove. Your question pertains to a gas stove. 2 things to look for: The most common of which is a weak ignitor. The second most common being a faulty sensor. Since you made no mention of a fault code I am going to assume the problem is the ignitor. For ignition to occur the gas safety valve has to release the gas to the burner. In order to do it the resistance on the ignitor must change. Over time the ignitor gets weak. One way to tell is by looking at it. It should be so bright you cannot stare at it very long. If it appears to be a dim orange AND you can bump the stove and sometimes get ignition then replace that ignitor.
Aug 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not work
With a gas range, I wouldn't fool with it. Get a service man out there now! Gas stoves are great untill they malfuntion and need a qualified service person to check it out. It's cheep insurance if there is a gas leek causing the problem. The alternitive-------!
May 21, 2009 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
635 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
