I own a Crate GFX 212T 120Watt. Turned the unit on and it worked great. Turned it off and came back later and it would not work. Any ideas?
    Genius:
  • 1,148 Answers
It could be a fuse ,,or ,,if its got the old style yubes,,, a power tube could of went bad ,,, good luck,, let me know if you need any more help,,, i deal with music gear daily in a band,,lol
Posted on Oct 06, 2008
I have a Fedders Window Air conditioner, model A2008F2BG. It was working great until today. Now it comes on but the fan wont blow much air. Any ideas?
I believe that is an older window unit. I don't know how difficult it is to get to the fan, but I would check to see if it can be cleaned, then see if there is any insulation or anything that is blocking air flow. I am assuming the filter is clean?
Aug 01, 2016 | Fedders Heating & Cooling
I have a crate GFX 50 and the effects come in only after about 15 minutes of play.
This is a warm up issue and can probably best be found by using circuit cooler on suspected components.
Other possible problems may be a bad solder joint or cracked circuit board.
Candle the board with a bright light to look for cracks.
Bad solder joints take experience to spot, but pay particular attention where panel mounted volume controls solder to the circuit board. Looking for the little ring around the solder menicus takes a sharp eye and good lighting. Resolder any suspected bad joints.
Jul 29, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate amp hums when it is turned but can work at times
has th amp got a valve if so the valve may need replacing or might need reseating..
Jul 31, 2009 | Audio Players & Recorders
I cant turn on my tomtom one. I turned the unit on this morning to input a couple of postcodes and turned it off again to save battery life but when I tried to turn it on again 10 mins later it wouldnt...
I found out the problem. The instruction manual does not tell you the unit has a reset button hidden in the back section. It is now working again
It is a little button which requires a fine point or ball point pen to push it. It is in alongside the connectors in the back.
Dec 14, 2008 | GPS
Wont start up
Sounds like you have a CD or DVD in your CD or DVD drive, or if you have a floppy drive, a floppy in it.
If these are empty, Put in your recovery CD and see if it reads that.
Jul 17, 2008 | Acer TravelMate 212T Notebook
Volume problem with BV120 tube head
hi.i suspect it is not faulty just built with different gain characteristics.only a power check with an oscilloscope will tell and any electronic repairer should do this for you very cheaply.it will also tell you how well and balanced the valves are.if you are near leeds.uk.i will do it for you nigel
Oct 25, 2007 | HHB Radius 50 Tube Amplifier
123 people viewed this question
 Grubhead
Grubhead
