Question about Rival CZF530 Deep Fryer
No power to controls
I have had the 530 for about 6 months bought at Target store worked fine till about a week ago . I have power from wall outlet to where the controles plug in as far as I know none from there to controles
  • dd59angelwin Jan 27, 2009
    i don't have power element for the deep fryer i need a new one is this possibe.to purchase one
My Cool Touch won't come on either. I wiggled the magnetic power cord and it came on one time but then, the second time, I tried wiggling the cord to relenquish the problem and zilch! Becoming more and more frustrated and since my fish was battered and ready to go I started pressing at the connections. It turned out that PUSHING THE POWER SWITH TO 'ON' AND THEN APPLYING FIRMER PRESSURE IN THAT SAME DIRECTION made the light come on, signifying POWER!!! Hope this helps. I imagine the problem lies in the 'ON' switch and by pressing it firmly upwards the connection is made.
Posted on Jan 27, 2009
Well first of all it is only 6 months old an being as it went down that soon an you do not want to repair it I am going to trash it an buy a good one like I had before for about 8 years an it will never be another Rival of any sort in my posession again beings that is as long as Rival products will last which is junk so in the junk it going so why should I spend more money above the about $60 i have already been out
Posted on Oct 07, 2008
My Casio ctk 811ex wont power up anyone more.Is there an internal battery that needs replacing ? What could be causing the problem ? 2 weeks ago it was working fine
ALWAYS start with the "easy" things 1st. Is the AC outlet on the wall working properly? Is the "wall-wart" power supply working correctly? If no defect is found, check the DC power jack located on the rear of the keyboard. Does it seem to be loose or does moving the power supply jack up/down cause any change? New wall-wart power supplies can be purchased from Radio Shack and usually at a lower price than the original factory replacements.
Mar 29, 2015 | Casio Music
Lights will not turn on
I experienced the same problem. One day the lights on the unit weren't on. The wall outlet that the dishwasher uses had power because the Garbage Disposal that also uses the same outlet had power. Turns out the power supply cord also tied to the water supply hose and had over the months (due to the constant slapping or dancing of the water hose whenever the electrically controlled water valve was opened or closed), had caused the female receptor prong inside the wall outlet to loose continuity with the male prong of the dishwasher power cord. It might have been a defective wall plug all along but the wall outlet worked for months before the problem arose. Anyway, after replacing the wall outlet the dishwasher again has lights and works fine.
Mar 06, 2015 | KitchenAid Dishwashers
Bought the tv three weeks ago it was the display model from best buy tv worked fine but now the tv powers on but no picture the green light on the front shows it's powered on but no picture model is...
okay i would advise you to take the tv back to the store you bought it from..probably its on warranty..have them replace the tv.and please dont open it or you will void the warranty.to make certain that the set is damage.pull the plug out of the power outlet let it stand for a whole day and plug it in back.see what it does.good luck.
Sep 23, 2011 | Toshiba 55G310U LCD TV
I bought LCD TV 32"
Check to make sure that the power cord is plugged in. If it is, plug something else into that outlet to test and make sure that the outlet works (use a lamp or something that you know works). If the outlet doesn't work, check your breaker box for a popped breaker. If the outlet works, and you are sure the power cable is connected properly, then you need to return the TV to the store where you bought it. Most retailers have at least a 30 day return policy for defective merchandise.
Apr 03, 2011 | Televison & Video
I bought a Uniden DECT 1035 last week and it has been working fine until yesterday when the screen went blank and only the status light was glowing. I charged it all night but still nothing has changed....
I would take it back to the store, there is a communication problem between the base and the remote phone, the only thing I can suggest is unplug the power and phone jack from the wall outlet for 30 seconds to see if the Uniden can reset.
Feb 10, 2011 | Uniden Cordless Phone
Oven just died on me!
The same thing just happened to ours which is just one year new. Waiting to hear if anyone can offer suggestions/feedback.
Mar 23, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
New oven, new installation. power at wall outlet, no power at ove
Open wire...either ground or neutral.
Lights are 110volt...and possibly there is a disabling feature due to open wire, as stated above, not allowing oven to operate.
When ground and/or neutral are provided all should work.
Feb 28, 2009 | Ovens
No sound from X-530 speakers
unless you are capable of replacing the jak on the speaker u need a new pair. the wiring functions the the jack which is now broken
Sep 30, 2008 | Logitech X-530 Computer Speakers
No Print
remove the cartridge and set it on an alcohol-soaked paper towel in the kitchen sink for about 15 minutes. If the towel has not begun to draw ink out, then tap cartridge firmly against your other hand which is holding the towel. if still none, then try heating the alcohol to about 150 degrees and repeat. if still nothing, then ink is either spent or cartridge head is dried up. take it to cartridge world (or similar outlet store) and they can get a cheap replacement.
May 31, 2007 | Canon BJC 3010 InkJet Printer
Rival CZF530 Deep Fryer Logo
75 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
