Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven not getting hot
Electric element is not getting red
  • jeffglaser Nov 11, 2008
    The oven has worked perfectly for 10 years then tonight we noticed that it would not heat all the way up. It got as high as 350 but could not get up to 450 which is what the dial was set at for more than on hour.
    Problem Solver:
  • 8 Answers
Age of unit could be a few diff things element could be bad control switch could be out or could be bad wire did it stop all at ounce or slowly elements go slowly most of the time bad wire or switch goes all at ounce
Posted on Oct 11, 2008
4 Suggested Answers
  • 1462 Answers
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Posted on Apr 16, 2007
  • 3 Answers
SOURCE: simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Posted on Feb 22, 2010
barkencoa
  • 3463 Answers
SOURCE: Zanussi ZDQ 595 fan oven not heating
You need to replace the round fan oven element located at the rear of the oven compartment behind a removeable cover where the fan is located.
Posted on May 14, 2010
Testimonial: "Thankyou - i did not know there was another element in there!! I cannot believe how expensive these ovens are considering the simplicity of their construction and low cost of the components inside.. Thanks again..!"
We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
Apr 02, 2016 | Ovens
Oven will not turn on after self cleaning has finished
If electric turn the oven to bake and look at the bottom element. If if does not turn red hot, it may be defective.
If gas, turn to bake and watch the igniter to see if it get red hot. If not, it may be defective.
May 22, 2014 | Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Feb 05, 2010 | Ovens
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Two of the elements on my stove get red hot (the little ones ) and the big ones don't get as hot what is wrong
the larger elements use 240 volts and your losing 1 leg of the 240volts and only getting 120volts to these elements
Sep 12, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Hi, my oven HOTPOINT UY46X is heating but not getting red hot. My husband has checked the fuse. Do you have any idea wha his could be?
Sounds like it could be low power as in only getting 120 to the element instead of 240. I would measure the power to the element and if ok the element will need replaced. Eric
Sep 03, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Jun 22, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven heating element stays on
If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
76 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
