RCA R52WH74 52 in Blue & red in picture are shadowy Picture concave/convex
    Genius:
  • 1,148 Answers
Try goin to your menu and find settings ,,go to convergence,,if u got it ,,it may fix it,,it realines the colors,,good luck with that
Posted on Oct 06, 2008
Red, Blue and Green Ribbon on Tv
converence power supply board is the most likely problem
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
TV rca hd 52w59 has convex picture. can I fix it.
If convergence adjustment did not correct the problem likely the convergence IC's have failed and will need to be replaced along with a few defective resistors in that circuit. If you have never attempted TV repair this would not be a good repair to start on.
The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test EQUIPMENT to determine what parts that are no longer within specs.
KEEP ME UPDATED..
Sep 29, 2008 | RCA D52W19 52" Rear Projection Television
RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA D52W19 52" Rear Projection Television
Picture in concave on all sides and blue and red are off
The shape of the picture indicates that the convergence circuit is not working properly. Generally speaking this occurs without making any sound at all. The popping you heard may have been a capacitor in the power supply. If the power line effected supplied the convergence circuit, repairing the supply should return the set to normal. If not, then the convergence ICs may be faulty. If you can solder, and are confortable working inside the set where potentially dangerous high voltages exist (even when unplugged), you may be able to repeir this yourself.
Let me know and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | RCA P52960 52" Rear Projection Television
Convex picture - can I fix it myself
sounds like the convergance ic are bad
http://serviceman.site88.net/index_files/Projection.htm
Sep 29, 2008 | RCA HD52W59 HDTV Projection Television
Screen lookes like colores separating
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Hd52w59 convex looking picture
If you do not see convergence in menu then you have open fuse FL231
Aug 28, 2008 | RCA D52W19 52" Rear Projection Television
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
Jul 02, 2008 | RCA R52WH73 Projection Television
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
