Question about Samsung BlackJack II Smartphone
Help -Blackjack II won't sync
All of a sudden,my BJII won't sycn. My OS is Vista Home Premium SP1. The computer "dings" like it recognizes that a device has connected, WMDC does not open automatically. When I open it manually, banner comes up but does not fully start.
Have tried uninstalling and reinstalling WMDC, deleting USB ports, setting up a new user, (all suggested by MS) still can get the phone to sync. One tech walked me through changing the settings on the phone in ActiveSync - that lost all my contacts and still can't sync.
  • 14 more comments
  • Joanne Glasser Oct 06, 2008
    It is on Active sync still doesn't work.
    I think firewall & virus software is disabled. Hard to tell with Norton 360.
    Problem seem to start after upgrading to iTunes 8. Do you think its thaat or do you think if I uninstalled SP1, the problem would resolve itself.
    ok we're getting somewhere. Disabled symantecs & windows fire wall - phone says to synchronie the device I must install Active Sync on desktop - with vista shouldn't need activsync.
    Restore is not an option - I wasn't syncing regularly enough to tell when it stopped working - doesn't apprear to be a Restore poiint around the time I first noticed the problem
    Sorry I don't understand that last one - my computer has Vista & not XP - How can I updarde phone Software if I cant sync?
    At some point since I started trying to fix this , I did uninstall iTunes but still couldn't sync the phone
    What is samsung pc studio
    Not a corrupted os file. doesn't work on another computer also running Vista
    I looked at doing asystem restore, but didn't have a restore point before the problem started
    Other USB devices are working fine. Under advise from MS delted all USB's and Vista reinstalled them at next start up
    How do I remove SP1?
    Am Ininstalling the WM remote Adapter as suggested. Its asking me if I want to delete the driver?? do I answer yes or no?
    Uninstalled the WM remote Adapter as suggested. Still won't sync.
    None of these suggestions worked
    How do you change OS to windows XP SP1?
  • 4,889 Answers
  • Samsung Master
  • 1,879 Answers
Uninstall the BlackJack II driver and make sure that the phone is disconnected from the computer.
You must FIRST install the disc that came with the phone (WMDC does NOT have the drivers for BJ II) and then RESTART the computer BEFORE you connect the BlackJack II.
If the steps above fails, get your computer's system / install / restore (whatever is labeled on it) disc and re-install VISTA.
Search the web for Blackjack II with Vista and it'll give you a gamut of issues from other customers.
Posted on Oct 06, 2008
  • 10,594 Answers
Want to shift to Win XP?
You need to format C drive to install Windows XP
    Master:
  • 763 Answers
If all the suggestions here using your windows vista didnt worked then try to change the Os windows xp sp1 and install again the pc suite of your phone or try to use it in different pc using windows xp. hope that helps!
CHARCOIS
    President:
  • 2,712 Answers
Please take a look at this link:
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=60081
You could also try restarting the PC in Safe Mode with Network Connections and thereafter it should sync automatically.
Found the following suggestion on a different forum as well. Could be worth a try:
***IF YOU'RE RUNNING VISTA ON AN INTEL MOTHERBOARD, YOU HAVE TO DISABLE "QuickResume Technology" IN THE BIOS!!***
ApparentlyIntel's VIIV QuickResume technology is not compatible with Vista, soeven if you've successfully installed the VIIV package AND thequickresume driver set, the setting in the BIOS can cause obscurehardware problems when enabled -- one of which is not recognizingmobile USB devices. The setting can be found in the Power sub-menu ofIntel's BIOS setup.
Hope that helps!
    Scholar:
  • 116 Answers
Yes you have to remove the drivers.
    Scholar:
  • 155 Answers
Try to disable startup items. Click start. In the 'start search' box, type in msconfig. go to the startup tab and disable all items except those for you antivirus. Click apply, close and restart.
Then try it again afterwards. Are there other usb devices connected to the computer that work fine?
  • 1 more comment
  • Rachelle Aviles
    Rachelle Aviles Oct 06, 2008
    If that doesn't work, try reinstalling WMDC. This time, install it by right-clicking the setup file (which you can find by exploring the cd) and clicking on 'Run as administrator'.
  • Rachelle Aviles
    You have to get buy a retail version of windows xp, format your hard drive and reinstall it from scratch. Have you tried reinstalling the software by running it as administrator?
  • Rachelle Aviles
    Try downloading this and run a scan on the computer. This is least likely a virus/spyware infection issue but you can run the scan to doublecheck.
  • 1,800 Answers
The problem is with OS configuration or corrupted files
try the latest asmsung PC studio if that deosnt work install new OS
  • Jalal Sordo
    Jalal Sordo Oct 06, 2008
    plz perform what i ve said u will se this is ocurs when a virus/corrupted files happend
    Master:
  • 479 Answers
Try doing the same thing with same settings on windows xp and it will work.many of the clients using windows vista OS are facing the same problem.some kind of software upgradation is required in the BJII to make it work.or the compitable software upgradation cd from vista dealer should be loaded on your pc to support.but try the same thing on windows xp and nothing will be required just enter the proper settings.it will work.
  • tech gurus Oct 06, 2008
    you can upgrade from any service center of your device.they provide this facility.but they will charge you for this.
  • Samsung Master
  • 6,487 Answers
What you can do here is try to do a system restore on the time that everything is working fine between the computer and the BJII so they are working fine after you just installed some update and other programs...
Hope that helps........
  • 3 more comments
  • Mark Gil
    Mark Gil Oct 06, 2008
    OK, if that's the case better isolation process here to check which one is really the problem here is to try syching this BJII using another computer , because if this BJII will be synch fine on a different computer we are now sure that the latest updates and changes on your vista computer is the one that is causing the problem, but if the BJII still wont synch using a different computer you may need to flash the software of this unit...
  • Mark Gil
    Samsung PC Studio is a Windows-based PC program package that you can use easily to manage personal data and multimedia files by connecting a Samsung Electronics Mobile Phone (GSM/GPRS/UMTS) to your PC.
  • Mark Gil
    Try to restore it if possible last month , the first week of the month so we can really check that the updates caused the problem...
  • Mark Gil
    You can restore it back on the date before you install SP1
  • Mark Gil
    Press yes to continue with that process...
    Genius:
  • 1,148 Answers
That all stems from having windows vista service pack 1,,all it is non stop problems ,,your better off without it , then you wouldnt have that problem,,i had 2 get rid of it,, good luck
  • 69 Answers
Try disabling our firewall and/or your antivirus and antispyware software. Sometimes, they block changes to the registry and system files that the phone needs to use. Make sure you disconnect your computer from the internet before you do though, so you don't get a worm or virus!
Have you changed any hardware or software since this problem started occurring?
What cellular carrier are you using?
These two links may help,
http://forums.cingular.com/cng/board/message?board.id=samsung&thread.id=46410
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=48027
  • 7 more comments
  • Kevin Croissant Oct 06, 2008
    If you have any Symantec internet protection software, disable that. It may be causing this to happen.
    You can do this to make sure it is disabled:
    1. Disconnect your device
    2. Select ‘Start…Run…Services.msc”
    3. From the list of services, stop Symantec & windows firewall
    4. Try reconnecting device and establishing a partnership.
    Yeah, we are getting somewhere indeed. Try removing itunes, but backup your music to a cd or elsewhere first. If you loose your music, Apple will not refund you at all. Period. Another thing you could try is DownGrade. meaning that you go from itunes 8 to the previous version when it worked.
    You could also try using System Restore.
    Have you ever used system restore? Its worth a shot.
    System restore(not a full restore, just a rollback) will turn back to clock to the time when the phone did work, and you should be able to use the sync again, without loosing anything. I highly suggest trying it.
    Hmmm...How long after you installed SP1 did you problem occur? That may be worth a shot[removing SP1 that is].
    Here is a guide from microsoft's site for removal:
    http://support.microsoft.com/kb/948537
    Try resetting the phone. I just thought of that. Maybe its not the computer after all...
    Its harder than you want. You
    ll have to upgrade to vista bussiness, and then downgrade to xp SP1,2,or 3
  • 749 Answers
The USB switches off ActiveSync to Mass Storage or Modem. Go to: Settings > Connections > USB > ...and make sure the setting in the selection window is set at ActiveSync.
  • Jeff Strader
    Jeff Strader Oct 06, 2008
    i had a similar issue, after about 2 weeks the computer stopped syncing with the phone. So, I went to the device manager to see if the device was even listed under the Network Adapters. It was there: Microsoft Windows Mobile Remote Adapter, so I deleted it, rebooted the PC, connected the USB and I finally got this installing device (granted I got that message before but this time it said: Microsoft Windows Mobile Remote Adapter was successfully installed, before it said 'unidentified device' installed although it showed the name clearly in the Network Adapters as MWMRA) then before I could click on the Windows Mobile device Center it said, SYNC IN PROGRESS. Opened the WMDC and it was syncing. FINALLY!! I was so elated after all this time all I needed to do was deleted it from the Network Adapter reboot (and maybe the uninstall/reinstalled helped) connect the USB and badabing badabong!! I hope it works for you. Good Luck. Oh and I didn't have to disable my firewall or make any other changes.
    Soo....try checking your network adapter section of the device manager, uninstalling the driver there and restarting the computer..
How do I reinstall Windows Vista Home Premium without a disk?
Most manufactured computers has a recovery partition installed to the computer. Suggest you access their support site for further info.
Dec 20, 2012 | Microsoft Windows Vista Home Premium SP1...
Is there a way to copy a photo/picture from facebook to my Blackjack II so that its on my phone?
Yes! I used to do this all the time when I had my BJII. Plug your phone into your computer and bring up the drive associated with it. Drag and drop the desired picture into the folder and you should be good to go.
Nov 30, 2010 | Samsung BlackJack II Smartphone
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Error states Spy Sweeper is not compatible with 64-bit operating systems.
This from the Webroot Web site on supported operating systems:
Windows Vista® (32-bit versions of Home Basic, Premium, Business, or Ultimate), Vista SP1 (32- and 64 bit versions of (Home Basic, Premium, Business, or Ultimate).
So, assuming you have bought the latest Spysweeper (and assuming you have Vista 64 bit) , then you need to upgrade your Vista to SP1.
Sep 12, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Driver for windows vista home premium sp1
HP doesn't have a Vista driver for Scanjet 3400c. I'm afraid your scanjet isn't compatible with Vista.
May 06, 2009 | HP Scanjet 3400c Flatbed Scanner
Mic volume reduced to almost nothing
Try getting a can of air and shooting into mic see if that helps ..could have gotten something in it..
May 05, 2009 | Samsung BlackJack II Smartphone
Unable to use my HSPA USB2 modem with Vista Home Premium SP1, on my laptop
There is a VERY good chance that your USB HSPA Modem is not compatible/complient with Microsoft Vista. There are very few older parts on the market that are compatible.
You can also go to the manufacture web site of the HSPS modem and see if there are any Vista Drivers. If not, then you are out of luck.
Sep 06, 2008 | Computers & Internet
HP Ipaq h1940 won't sync with Vista
use microsoft windows mobile device center
Jun 11, 2008 | HP iPAQ H1940 Pocket PC
Philips HDD6330/17 suddenly not recognized by Vista
Check which version of Windows Media Player you have loaded.
Open Windows Media Player. Click "Help" and "about". This should show which version you have.
Windows Automatic Updates may hve updated to version 11.
The Philips HDD6330 is only compatible with version 10 under Windows XP.
If you have version 11, then uninstall and it should roll back to version 10.
Dec 22, 2007 | Philips GoGear HDD6330 MP3 Player
Samsung BlackJack II Smartphone Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
