Question about LG Washing Machines
Our washing machine, model #WM2077CW, is flashing the error code LE. Can you perhaps fill me in on the situation?
  • 706 Answers
LE means a Locked Motor Code: ( these are the manufacturers list of issues associated with that coed...)
• The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
Posted on Oct 06, 2008
Lg washer wm2077cw had le error and did not work, blew in to tubing connecting tub to a sensor at top and now my reading went from 230 to 256. washer wont stop filling , leaks out front door. what is wrong...
When you blew into the tubing, you destroyed the water level sensor. You will need to change the water level sensor to stop the unit from over filling. That part number is 6601ER1006E. As for the LE error code, you one of 2 things go bad. Either the motor sensor has failed or the control board has failed. Chances are the motor sensor has failed and is the cheaper part to replace. The part number for that is 6501KW2002A
Good luck
Aug 03, 2011 | LG WM-2277HW Front Load Washer
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
Washer won't fill. code LE
Try unplugging and replugging. Apparently it does a reset of something. It worked for me. I would make sure you don't have to much laundry in the machine too.
Dec 10, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE CODE AND A BURNING SMELL
The LE code represent a failed or locked motor. the replacement of the electrical motor will be needed in this situation.
Jul 19, 2009 | LG WM2077CW XL Front Load Stackable Washer...
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
LG washing machine Model # wm2077cw
LE is a locked motor error. If this happens often then 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure. The part is relatively inexpensive and easy to replace.
This can also happen if the motor is overheating slightly from being overfilled (too many clothes) or if you do one load after the other and do not allow at least 10-15 minutes between loads for the motor to cool down. In this case the LE error will only happen occasionally.
Hope this helps, please rate my solution.
Jan 11, 2009 | Washing Machines
Wm2077cw
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Use powders for 'front loading machines'. And pl rate me if helped.
Jan 10, 2008 | LG WM-2277HW Front Load Washer
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
158 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
