I have a Mitsubishi VS-5047 PROJECTION TV The other day it just turned off I pulled the back cover off and the main power source fuse was blown. I replaced the fuse but the tv power button comes on for about 3 seconds then it just shuts off again. This TV IS from 1996 is it worth fixing.
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Posted on Aug 19, 2008
SOURCE: Mitsubishi VS 5047. Won't turn
I had just put in about $500 worth of work into this TV to clean the color tubes of bacteria and other miscellaneous problems - They kept my TV for 3 months before bringing it back. It worked for 2 days and then everything went green, so they came back and took it for another 30 days before bringing it back.
This new problem could have been anything as simple as a tube to a circuitry problem. We decided to junk this Mitsubishi product. I have a 30 year old Curtis Mathis TV that I've never had any problems with (that's 3 times the age of the Mitsubishi).
We've opted for a new 50-inch Panasonic Plasma with the anti burn in technology. I will not buy another Mitsubishi product, or a rear projection TV of any brand after this experience.
Posted on Aug 24, 2008
SOURCE: need internal parts for mitsubishi projection tv for 1993 model #VS-50VA1
No clarity - dim picture with screen becoming light green with vertical lines
Posted on Oct 30, 2008
Sparko1
  • 167 Answers
SOURCE: Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Posted on Aug 03, 2009
johnnydiode
  • 647 Answers
SOURCE: Where can I purchse new lens/lamps at for my
Is this a CRT (picture tube) or LCD, DLP projetion set. DLP and LCD are lamp driven CRT have three picture tubes (red green and blue). You can tell by looking at the back pof the set if you see the glow of white light than it's a LCD or DLP. Lamps can be purchased at "bluestar international" ($100-$400) (google it) and CRT's are not worth replacing (over $300 each_)
Posted on Sep 20, 2009
Have a dark band horizontally across vizio tv. Appears to be a backlight, but not sure how to fix
Could be a bad CCFL lamp, if the set usess CCFL back-light system. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 08, 2017 | Vizio Televison & Video
Samsung plasma TV model #pn42b400p3dxza problem with no image. The TV has sound but no image. I've tried using other components on the TV like RCA jacks with a separate TV digital tuner. Thank you
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Check whether Va & Vs voltage come to the display panel, from the main power supply regulator board. If not, the SMPS board [power supply regulator board] is faulty.
Jan 08, 2017 | Samsung Televison & Video
MY SAMSUNG TV IS ONLY SHOWING A BLACK SCREEN WHEN IT POWERS ON THE MODEL NUBER IS UN60EH6002FXZA WHAT DO U THINK IS WRONG WITH IT
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
Jan 07, 2017 | Samsung Televison & Video
Picture has just started to dim after being on for 5mins. Light sensor is off.
Jan 07, 2017 | Televison & Video
I was using my Samsung LCD 40" - LE40M86BD [R] when it just switched off and wouldn't come back on. What could it be? Thanks guys
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. . If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 07, 2017 | Toshiba Televison & Video
S/n z5qq3c5d947793y m.c un32eh4003fxza will not coming on 32 flat Tv
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
I can hear sound but no picture I have a Hitachi 55 inch
Jan 06, 2017 | Hitachi Televison & Video
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
