Question about Samsung Yepp YP-T9 Digital Media Player
Mi pc no reconoce el dispocitivo cuando lo conecto
Tengo un samsung yp-t9j trato de conectarlo a la pc y no lo reconoce
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: mp3 no lo lee mi compu
Firmware upgrade needed - RCA website - select "Spanish" for language
Posted on May 24, 2008
SOURCE: recognizing samsung yp-u3
my computer say when i go to connect it cannot connect i onli got it today do u know what i cud do??
Posted on Jul 22, 2008
SOURCE: PROBLEMAS CON MI SAMSUNG YP-U2J
http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U2JXB&language=&cate_type=all&dType=D&mType=FM&vType=R&prd_ia_cd=03040200&disp_nm=YP-U2JXB
http://everydayasp.net/archive/2007/08/20/samsung-yp-u2j-mtp-connected-problem-firmware-update-required-version-001-156-876.aspx
all u need to fix it
Posted on Nov 10, 2008
SOURCE: software for yp-t9j
I LOST MY CD SOFTWAER
Posted on Jan 17, 2009
Tengo un mp3 gogear sa 1945/55 y no prende ,cuanod lo onecto al ordenador la pantalla se pixela y no lo reconoce use el philip desvice manager y ahora no prende , no lo reconoce , y cunaod lo conecto usb...
yo tenia el mismo mp3. es un problema de los phillips. no ay mucha solucion para esto. trate de apretarle el reset button si esto no funciona trate de llamar a la compania. alomejor el device se le cayo y por eso no funciona
May 03, 2011 | Philips GOGEAR SA6045 MP3 Player
Mi ford f 350 5.8L 1995 Tiene el problema que cuando el motor esta encendido y enciendo las luces el motor se apaga si trato de ensenderlo con las luces ensendidas no ensiende Que podra ser ...
tengo problemas con mi caminoneta f350 ford el systema de four well drive cuando lo tengo en neutral la camioneta no camina en camvio ni para atras o para delane cual sera el problema.
Jan 07, 2011 | 1995 Ford F350
Mi problema es que mi netbook inspiron mini 1010 cuando le conesto el raton B_MSLU NANO 23501 y tambien me paso con otro inalambrico pues me lo reconoce y funciona durante unos segundos, despues deja de...
Hola Asaiol
Trata conectando el cable USB a otro puerto de la computadora. No uses USB hubs (concentradores) sino que debes conectarlos directamente a la computadora.
Tambien coloca el "wireless receiver" cerca de tu mouse.
Eso deberia funcionar.
Jan 12, 2010 | Dell Inspiron Mini 10 Notebook
Como puedo instalar los drivers de la camara web. Cuando conecto la webcam, la pc me PIDE que Inserte el CD pero me dice que no encuentra los archivos . Puedo descargarlos de algun lado? es una GE 98650,...
ok necesitas bajar el driver directo desde la pagina GE 98650 y si es posible el software que viene con ella si es que perdistes el disco. Verifica si a camara es compatible con tu sistema operativo.. o si ya salio un update para ella que resuelva el problema.. Todo se resolvera bajando thel propio site de la camara las ultimas drivers y actualizaciones... Por favor dale a click que mi informacion te ayudo suerte o me avisas para darte otros pasos
Dec 28, 2009 | GE EasyCam Webcam
Problema tarjeta sabrent
Hola, que tal yo tengo un problema también con la TV Tuner de Sabrent, pero en mi lap tiene Windows Vista y no me detecta audio.
¿Cómo le hiciste tu para que detectara audio al sintonizar la TV y capturar video?
roy_villafuente2510@hotmail.com
Dec 02, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Mp3 no lo lee mi compu
May 12, 2008 | RCA TH1101 MP3 Player
Ayuda
Te recomendaria que utilizes un transformador variable para que puedas hacer mediciones del voltaje que alimenta la seccion horizontal. Me parece que la seccion horizontal esta recibiendo mucho voltaje y es cuando se activan los circuitos de proteccion.
Si usas el transformador variable empieza con 80VAC y mide la DC en tu TV, si en la entrada de el regulador de voltaje tienes mas o menos 130VDC a la salida tienes lo mismo, el TV te funcionara. Despues incrementa es voltaje a 100VAC y vuelve a hacer las mediciones.
Si despues de incrementar el AC a 110VAC el TV hace lo mismo, trata de medir la DC en la salida del regulador de voltaje. El voltaje aceptable seria de 130VDC a 135VDC.
Suerte.
Jan 16, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Samsung Yepp YP-T9 Digital Media Player Logo
142 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
