Question about Pentax Optio A20 Digital Camera
Display screen went white..
The screen of my camera become white. It is displaying nothing.Can you please help in fixing the problem. i will be thankful to you.
iqbal grewal
  • 3 more comments
  • lancecox Nov 16, 2008
    white screen when i turn on my pentax optio a20 no image please help
  • Anonymous Jan 03, 2009
    display is white
  • xic044 Feb 17, 2009
    Screen goes white when I turn the camera on. Nothing happens. To turn it off I have to remove battery
  • Anonymous Mar 12, 2009
    white blank screen when switched on . i have to remove battery to switch off.
  • Anonymous Mar 28, 2009
    I have a Pentax optio A20. the Display has become white. I can click photograph and in my computer it shows all the colours but while clicking can't see the image or after clicking I am unable to view it . I will be thankfull if someone is so kind to help me to shortout my problem. If there is any solution please mail me to abhi.sural@gmail.com
    Regards
    Abhijit
Your screen is not connected inside your camera it is easy to reconnect as there is a cellophane tab carrying copper connectors that are held in with a plastic clip which has probably unclipped itselfyou need a watch makers screwdriver (small possidriver a eye glass and a pair of small strong tweezers) work on a clean table so if you drop the small screws they can be easily found 6small screws in allI replaced my own screenthat I got fromASAHI PHOTO LTD MDDX on ebaycost was £39 .95 and a genuine replacement screen a doddle to do as it requires no soldering just a bit fiddly hope this helps
Posted on Jul 08, 2009
  • 25 Answers
If the screen becomes damaged, it can turn all white. The white is the backlight, and if the screen is dead, you will see all white. This is not the ONLY cause, but it is one of the most common. If you are vary handy, and good with very small parts, then you can buy a screen on ebay for about $20-25 and fix it yourself.
I fix ALL Pentax Optio A10,A20,A30,A40 models. My price is between $40 and $100 for almost any problem. I will replace your screen for $40, if that is the problem.
I also buy all the Pentax models listed above, in ANY condition.
Email me: MrFixItMark@comcast.net
Posted on Jun 09, 2010
The screen of my camera become white. It is displaying nothing. Can you please help in fixing the problem.
Posted on Nov 16, 2008
Please I need help on my machine, cannon IR2016. it displays nothing on screen. what could be the problem and how can i fix it?
Nothing displays on screen on IR 2016 . Dear. you may check the flat cable connected with the display unit which becomes faulty . change the flat cable then it will show everything on screen.
Feb 13, 2017 | Canon imageRUNNER 2016 All-In-One Laser...
The screen is all white
You need to re-seat replace the ribbon cable that is connecting screen to main board. Possibly out place after unit was dropped.
Sep 07, 2009 | Sony Ericsson K510i Cellular Phone
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
Nokia display become white
the crystal diode behind the lcd screen has been damaged causing this "white screen".
best chances are to replace the whole lcd screen to get the display in working order again.
cheers.
Jan 23, 2009 | Nokia 3250 Cellular Phone
Screen does not display
I had the same problem. more than likely your connector cable between the camera and the display has become brittle over time and is beginning to break. as you open the screen the small wires inside the cable are separating. mine went from 30 deg view to 90 deg no display as yours is now, then 30 deg fuzzy display (cant make out the picture like a VHS when it needs heads cleaned) then the cable gave in and snapped. all the way through. Simply not a lasting camera. I got quotes and it was about $200 to fix. for that price these days u will pick up a better camera anyway. Good luck
Nov 19, 2008 | Panasonic NV-DS60 Mini DV Digital...
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Display problem
i also have the same problem...white screen display
May 26, 2008 | Nokia N70 Cellular Phone
My camera display screen is only showing weird colors but works when I take pictures
A loose connection perhaps
A gentle taspe may restore it - or it may not.
Canon support will advise on your next move
Sep 14, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
A blank screen
Blank white - suggests a dislodged connector These tend to be at the base of the screen gentle massaging and pressure may re establish it. Fuji Tech support team may help further
Jul 02, 2007 | Fuji FinePix A345 Digital Camera
Pentax Optio A20 Digital Camera Logo
600 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
