Question about KitchenAid Refrigerators
Kitchenaid Refrigerator - Side by Side - Wiring Harness Problem
Model # - KSBS25FKBL00
Serial # - SM0355530
The filtered water does not work on the freezer door. The ice maker still works. We changed filters but didn't help. Called local appliance repair service. He has seen many of these refrigerators in our area and has encountered same issue with many. There is a wiring harness problem that has occurred with many of the same refrigerators. He referred us to you insofar as repairman says that many of the refrigerators with the same issue have been replaced under warranty due to the recurring issue. Appliance man disconnected the left harness for safety reasons. Would like to have someone from Kitchenaid take a look for replacement purposes. Thank you.
Lexi Tehven
2993 Greensborough Dr.
Highlands Ranch, CO 80129
303-600-8213 home
lexitehven@comcast.net
  • 333 Answers
SOURCE: location of refrigerator water filter
The filter should be a canister somewhere in the line from your sink to the refrigerator. If there is no canister visib;le there then obviously they never installed a filter in the first place. I hope this helps. Don't forget to rate my answer. thanks.
Posted on Feb 21, 2009
falter
  • 245 Answers
SOURCE: Kitchenaid refrigerator smells.
hi feel sorry for u but if u have all this problems already... why don't u ask the company or store u bought this LEMON..... so replace it or get money back...otherwise go in contact with customer protection and complain to them,,,,,
hope u get a satisfactory answer.....
Posted on Mar 11, 2009
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Posted on Dec 22, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
heatman101
  • 43501 Answers
SOURCE: refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Posted on Sep 30, 2010
KITCHENAID REFRIGERATOR KSBS25FKBL00
there is a defrost control board in the box where you turn up the temp on the right it will control that .
Mar 30, 2009 | KitchenAid KSBS25FK Side by Side...
Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
May 13, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Water filter
I don't think this model has a filter, I checked under the kickplate, no filter there.
Mar 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Mar 21, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen aid Supra
At the top left hinge there shuld be a cover over the hinge. Remove that cover and check to see if plug connectors are securly plugged together. Double check the right top wall of the refrigerator section and verify the model # I did not locate info on the model you posted.
supertechks
Nov 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
I had two (2) broken wires in the harness. I don't think you actually have to take the door off. It may be a little cramped working, but I think it can be done. Once you take off the bottom grill, find the end of the harness next to the water filter and unplug the white plug. Just below that is a ground wire. Remove the screw and take the green wire off. Then, next to that is a white "c-clip" holding the harness against the bottom of the refrigerator. Remove that clamp and you should have enough "play" to work on the harness. (It is probably a pain in the #*@ to remove the entire harness because it runs into a hole in the bottom of the door and then up through the door itself) You'll have to cut away the black mesh sleeve over the harness. I cut it with a pair of wire cutters as close to where the harness goes into the door as possible. There may also be a bit of black electrical tape at the end of the mesh closest to the white plug. Remove that, and you should be able to slide the mesh sleeve off, over the plug. This should reveal the broken wires. I just took some 12 gauge braided wire and cut a couple of pieces
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Filter
Water filters for most refrigeration cabinets are located externally to the cabinet as they are quite large. If you have one you would know. If you dont have one fit one as they make a large difference. Once fitted make sure you run the water through. Hope this helps.
Aug 17, 2007 | KitchenAid KSRS25CNBT / KSRS25CNLK /...
Refrigerators Logo
98 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
