Question about Linksys Wireless-N WRT150N Router
Port fowarding and remote desktop
I have a linksys Wireless N Broadband Router model # WRT160N. I have tried countless times to enable port fowarding so I can remotely access my home network. I can log into the router fine from home. What do I need to do to enable remote login? Do you have a site that includes step-by-step intructions?
  • bmerkt Dec 03, 2008
    I have the same problem, I have everything set right. on the router and the PC. Can access remote desktop on the lan, but not outside. www.grc.com shows everything stealthy. www.canyouseeme.org shows port 3389 open. A static ip is assigned to the host machine and configured on the linksys with a IP reservation. netstat /a show port 3389 listening. Port range forwarding both protocals to port 3389 is enabled on the linksys. The ISP is not blocking the port. I have a simple workgroup config behind a Winstel DSL modem and a WRT160N, I know this stuff and can usually figure it out but this one I cannot. I even reset the router and rebuilt the network. UNCLE!!
  • 928 Answers
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Posted on Oct 06, 2008
I have got a WRTP54G Switch Ihave lost the CD I need to set a password to WIFI in it how can i do
Hello Friend
Please open page with address 192.168.1.1 and open the router page with username= blank
password=ADMIN
Go to wireless tab and click on the security
Click on the secutiy box and enable this.
Set this to WEP or WPA
Enter the passprase\password which you want tas a password for your wireless network.
Enter these details
You can also check this user iterface here.
http://ui.linksys.com/files/WRT160N/v3/3.0.00/WL_WPATable.htm
Jul 22, 2013 | Linksys WRTP54G Wireless-G Broadband...
I have a Linksys WRT160N wireless broadband router. When I get on Xbox Live it says that I have a strict NAT type and I want an open NAT type. I have already enabled the DMZ, UPnP, and put in the proper...
try this :
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9. here is the site with an example page to configure your router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
Aug 21, 2010 | Linksys WRT160N Wireless Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
Compatibility with high speed ADSL2 Broadband
Yes, Linksys WRT160N is 100% compatible with ADSL2. Linksys WRT160N is a Broadband router.
you will not be able to use the linksys WRT160N, as an ADSL2 modem router. you should be using an ADSL2 Modem separately and connect the cable from the modem to the Linksys WRT160N. Hope this clarify the doubt.
Apr 02, 2010 | Linksys WRT160N Wireless Router
Cant obtain ip adress
Have you set up your lynksys to allow wireless QoS? If not go to your lynksys broadband wireless software. If you don't know how enter 192.168.1.1 into your explorer bar, log in with lynksys, default is top line blank password 'admin', go to Applications and Gaming tab and enable Wireless QoS, you'll also see all of the places to establish and open ports for specific applications.
May 09, 2009 | Linksys WRT160N Wireless Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Do i need a modem for my linksys WRT160N Broadband router of enable to connect to my dsl, or can i connect directly my dsl cable to WRT160N Broadband router. Thanks in advance
Greetings,
You need to have a separate DSL modem
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Linksys Wireless-G Broadband Router
Port Fowarding
Here is a listing of programs and how to forward them for your router.
PortForward
Feb 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-N WRT150N Router Logo
606 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
