Question about KitchenAid KSRG25FK Side by Side Refrigerator
Warm on both, freezer and fridge sides
We were away a few days and upon return the freezer side and the refridgerator side were both warmer than room temperature. We, obviously, lost the contents of both sides. This unit was purchased on Novermber 30, 2003. Seeing other customers with the same problem it looks like there is a major problem with this KitchenAid model side by side.
VTFLTN55@CHARTER.net
  • thubert3 Mar 22, 2009
    Woke up this morning and the freezer on side by side unit was not working. The refrigerator seems to be ok.
  • Anonymous Apr 22, 2009
    I have similar problem; fan is running and blowing "cool" air, but not cold. What did the technician do?
I called KitchenAid and they are sending a service person to check it out.
Posted on Oct 06, 2008
Have been away over weekend and returned to find that the fridge side of the unit is not working it says its at 1 degree but is considerably warmer, milk and meat have gone off. It has come up with an...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 106.63854302 Coldspot is not holding temperatures
Hi i had the same problem and someone came in it was well worth it it was the relay button and it only cost $50.00 for the part .
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Refridgerator
Hi. thanks for the question. the heat between the doors is normal . to solve . pull the fridge away from wall .remove back panel. clean all lint in coils .Dust in the coils causes the heat between the doors to get warmer . so cleaning of coils. will solve the problem thanks the appliance doc
Oct 04, 2008 | Jenn-Air JCD2389G Side by Side...
Warm side by side freezer and fridge
hi thanks for your question. i would clean the coils at the back of the fridge. it could be just dusty try that
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Refridgerator was never that cool now its warm
put a thermometer in the refrigerator and one in the freezer to see what it reads each day when you had the freezer open it it coses it to work harder like having an air conditioner on with the window open it has to work harder to keep it cold so by recording them temp to see if its dropping or it stays the same you might have to get it looked at but for just getting it a week ago it should not have hurt anything just leaving it open a little bit might just be normal for it to be hot i have a side by side and the side is hot but not to hot just warm. let me know hope that helps
Jun 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
KitchenAid KSRG25FK Side by Side Refrigerator Logo
162 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
