Question about Olympus EVOLT E-500 Digital Camera
Olympus E-500 - Flash not working at all
Hi, my built-in flash has stopped working all together. Why is this? Do i need to replace it? Can i replace it? or is there something else i can do?
Thanks
  • Anonymous Oct 14, 2008
    I have the same problem. Resetting did not work. I did discover that I can "manually" release the flash by sticking a fingernail in the crack in the front where the flash meets the body and exert slight pressure towards the back of the camera. The flash then works properly.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
You will need to try to reset the camera first through the camera menu by placing the camera mode to P, press menu, right arrow to card, down one to custom reset, right arrow, ok, yes to reset. else you will need to send to repair center
Posted on Oct 06, 2008
The onboard flash just stopped working
It's either the charging circuit, the capacitor or the flash tube, but unless your camera is still under the Olympus two year worldwide warranty (if purchased from an authorised Olympus Dealer within Europe, proof of purchase required) then you'll have to either send the camera to Olympus for a repair estimate (this costs £15 if you choose to have the camera returned unrepaired) or take it to an independent camera repairer for diagnosis.
The above links/prices are for the UK but should help you navigate to your own country if different.
Alternatively, don't bother with the repair of the pathetically weedy onboard flash and invest the money on a proper external flash instead. You don't have to buy the overpriced Olympus/Panasonic offerings; there are cheaper non-dedicated flash units (you'll need to learn a little bit about how to use them, but they are VERY cheap) or you can buy the excellent Metz 48 AF-1 which is available as an Oly/Panasonic unit and in the UK/Europe is cheaper than a genuine Oly/Panasonic flash. Metz are the undisputed market leaders in flash units and always retain an excellent resale value.
Hope this has helped you, please return the favour by taking a moment to rate my answer.
Feb 11, 2010 | Olympus EVOLT E-500 Digital Camera
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Bulb replacement for Sigma EF-500 DG Super
So I had fixed the problem this morning, since the warranty has expired, I opened up the flash to take a peak on the inner workings, and found that a wire had come loose, got out the soldering gun and repaired the connection and all is good.
Sep 28, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
Olympus E-500 flash smelling like burnt plastic
You should contact Olympus about this.
Olympus have had a recall on some older 35mm film cameras for problems with the flash circuit.
Please see -
Olympus Recall
http://www.olympusamerica.com/cpg_section/cpg_recall.asp
Hope this helps,
Vincent
Jul 08, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
My Olympus Stylus 500, doesn't work the flash
hi
have you tried using lithium batteries? alkaline batteries. just try out different batteries. if it is still the same, have your camera checked in a service center for maybe it needs a replacement or there is something loose inside.
hope this helps.
Jan 28, 2008 | Olympus ? Stylus 500 Digital Camera
Olympus µ Digital 500 flash is not working. Flash indicator keeps on blinking. But when the flash is off, the camera can take pictures. I also notice that the battery and memory card get hot when the...
This suggests the flash capacitor has malfunctioned
Check Olympus for a warranty replacement or repair cost- according to age of camera. If it is an older model a new camera may be best bet
Dec 20, 2007 | Olympus ? Stylus 500 Digital Camera
Stylus 500 flash
hi
have you guys tried using other battery types like lithium and alkaline? if its not with the batteries, have it checked out in a service center because there might be a an issue with the charging for the flash.
Oct 10, 2007 | Olympus ? Stylus 500 Digital Camera
Flash indicator keeps blinking
i have the same problem. i dont think the flash is working.. i think the bulb needs replacing. i wish i knew a place to get it fixed or a place to buy a bulb...
Aug 05, 2006 | Olympus ? Stylus 500 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
174 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
