Question about Hotpoint Aquarius WMA42 Front Load Washer
PERFORMA WASHING MACHINE
I need to put the drain hose on and can not figure out how it goes on thei swashing machine
  • Hotpoint Master
  • 3,463 Answers
To fit drain hose on WMA range of washers you need to remove the lower rear back panel. At the right hand is the pump, this is where the hose connects to
Posted on Nov 28, 2008
Replace drain hose
if u add an extension to the drain hose it will take a long time to and go down the pvc pipe. Just check for clog. by giving it for service one time may work.
Nov 03, 2013 | Maytag Performa PAV2200
Water drains straight out and does not fill machine
Lift the drain hose so that the hose is higher than the lid on the machine. At the moment it sounds like the hose may be laying on the floor?
Apr 12, 2010 | Maytag Performa PAV3200
Why my Maytag model performa, washing machine fill
Check drain hose not too low ...Syphon Effect....Good luck
Sep 29, 2009 | Maytag Performa PAV2200
When starting to wash water goes straight out of
The drain you are putting the drain hose into needs to be at least 30 inches above the floor. You probably have the drain hose to low or laying on the floor for this to be happening.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
Maytag performa washing machine
yes im a expert (laugh)...your drain hose is to low..the drain hose must go up the height of the unit abut 3 feet before it can go down...now if you have your drain hose connect directly to your drain pipe ,,the waste pipe will **** the in coming water right out of unit,,we call this a sphion effect...booth easy fixs,,,onthejob
Jan 22, 2009 | Maytag Performa PAV2200
My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to...
the washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Feb 29, 2008 | Washing Machines
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
HELP!!!!!!
Before spinning, washer draining water aut & than start spinning,,,,if motor runing without drainig water, chek the belt, if belt is OK,and runing pupm, chek the pump,,,,disconnect hoses and clean pump... if washer do not draining & spinning, replase lid switch..... If you need instruction how to replace lid switch, i will post you instruktion....
Sep 01, 2007 | Maytag Performa PAV2200
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Hotpoint Aquarius WMA42 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
