Question about Mitsubishi WS-55859 55" Rear Projection Television
TV will not power up. Timer light continues to flash, will not reset.
TV was unpluged, moved, and pluged in after 10 min. Timer light flashes, and continues to flash. It will not reset. The light does go out when reset is pushed.
  • jetmecha6 Oct 06, 2008
    I Checked the fuzes, still does not work.
    The Light that goes out is the timer light, you can hear the reset switch click and when you release the switch, the timer light resumes blinking. No other lights or sounds are noticed
  • 10,594 Answers
If you have bit electronics knowledge and know about tv repair, please check power board. There are few lose connections are cold solder joints.
This is the reason tv wont power up.
Good luck.
Posted on Oct 06, 2008
  • Shahid Electronics
    Shahid Electronics Oct 06, 2008
    If you need TV's service manual, you can download it from Here, it is free.
    Guru:
  • 1,894 Answers
After the light goes out do you notice any blinks of the stand by light?
and do you hear sound?
because you dint say anything about the sound
    Genius:
  • 1,148 Answers
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
TV went off, standby timer light flashing
Try unpluging from the wall and theplug back in and try turning back on to reset. Sometimes holding the power button in while pluging back in will reset it, every brand is different for the hard reset.
Scott
Apr 17, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Lamp light flashing green continually after power outage. have hit reset button, unplugged tv, nothing works
the timer light will continually flash green.on the dm pcb and fmt pcb you have 4 capacitors
that pooch out.replace the 4 capacitors on both boards.will require a tv professional to do
this.
Jul 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
My pixma pro 9000 Canon printer will continues to flash the yellow light and the on light and will not let the ink cartridges move to the middle to change the catriges
hmm..turn it off..unplug from wall outlet..let it set for 3 min
hold down power button, and plug back in wall..with button depressed.
release button after 10 seconds
that might reset the power situation.
Aug 20, 2008 | Canon Office Equipment & Supplies
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
No Power.
You might have blown a fuse inside the TV. Lots off volts can go into those TVs. Make sure you are under warrinity and return the thing. Maybe also a malfunction.
Nov 10, 2006 | Mitsubishi WD-65000 65" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
