Question about Dell Optiplex GX110 (2909T) Motherboard
CPU upgrade optiplex gx110 motherboard
I am trying to upgrade pentium3 733mhz to 1.4ghz when I switch cpus and try to power on I get a orange light and nothing else .My bios is a08 does that have anything to do with it?
The 1.4 GHz chips are Tualatin cores- they use a different voltage than your previous chips and as such you would need an adapter that fits between your socket and that CPU... It is very bad for that chip and your motherboard to continue trying to run is as-is so I would stop powering it up with it in there immediately if you already haven't done so. I'm in the same boat as you with an Optiplex gx110 that I really love, but I'm stuck with my 933 [Which by the way you COULD run up to a 1 GHz PIII Coppermine in that thing] and my 1.4 sitting on the desk until I find a suitable adapter on eBay or something.... Once I have the adapter, I still don't know if the bios will play nice.
Hope this helps at least a little!
Posted on Oct 31, 2008
I have this system and was successful upgrading the processor. The key to success is downgrading the BIOS to version A05. Once this has been done you can install the new processor and enjoy.
Dennis
Posted on Jun 23, 2009
I have dell 960 switch it on but light turns to orange
Could be several things.
1. could be the power supply
2. inspect the motherboard for bad caps.
If the above is OK. Try removing and reseating the CPU, Memory and CMOS battery.
Apr 15, 2014 | Dell OPTIPLEX 960 MT Desktop Computer...
Unknown cpu detected asus.Bios update is required to unleash its full power.
You will get this message when you install a CPU that is not supported by the mainboard BIOS. Many older mainboards have sockets that will support much more powerful CPUs than they were originally manufactured for. In some cases, the BIOS may be upgradeable to support the new CPU, in others, the CPU may draw too much power or the mainboard chipsets will not support the CPU capabilities. If your CPU is on the list of compatible CPUs...you may need to upgrade the BIOS to support it. You will need to install a CPU that the mainboard will run with to do the BIOS upgrade prior to installing the new CPU, however.
Jan 03, 2014 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I have tried to change the ram and every thing but the computer wont boot up only ends with an orange light thats all.
always place the ram with the biggest closest to you CPU central processing unit and try to keep it the same brand/type if you have done this to no satisfaction
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 19, 2010 | Dell Optiplex GX110 (2909T) Motherboard
Sir, I have a Dell optiplex GX110. At the motherboard there is a long brown slot in which a board of 4 expansion slots has been pluged. The first problem was that I had removed the heat sink from the...
When you inserted a test probe into the slot and you saw a spark, then you have short circuit a component on the motherboard and have done a major damage to the motherboard.
You need a new motherboard, most desktop cases have standard mounting holes, you may be able to purchase a motherboard from other manufacturer to fit in the Dell.
Oct 09, 2010 | Dell Optiplex GX110 (2909T) Motherboard
My desktop Dell optiplex gx110 won't start.only solid orange light.
try to repair your oparating system please use the second repair option
Dec 07, 2009 | Dell OptiPlex GX110 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell Computer Refurbished Optiplex GX260
from what I can tell you can use NORTHWOOD CPUS or POWERLEAP modified cpus on the GX260 but not prescott. as these are incompatible
http://support.dell.com/support/edocs/systems/opgx260/en/ug/specs.htm#1110653 would suggest 400 or 533 based P4s
using Powerleap's configurator http://www.powerleap.com
it appears that it is possible to use an Intel P4 3.06GHz 533MHz 478pin 512K Northwood CPU w/Hyper-threading OEM
Oct 03, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
Motherboard problem
if you have another power supply around or can borrow one try it.
Sep 22, 2008 | Dell Optiplex GX110 (2909T) Motherboard
Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex GX110 (2909T) Motherboard Logo
1,126 people viewed this question
Alun Cox
