Question about Samsung DLP HL-P5663W 56" TV
Fan Noise When starting and turning off, a noise like a bad fan is heard. Is this related to the lamp or are there not moving pats on the lamp? Is there a cooling fan like in most computers that could be going bad?
  • thrashxcore6 Jan 27, 2009
    i have the same problem with mine when i turn it on it sounds like a fan all rusted how did you solve this problem anthony in stockton email me at thrashxcore625@live.com 209 5949252
  • 41 Answers
There is a cooling pan inside... replace the cooling fan inside..
Posted on Oct 06, 2008
Replaced the balast, tv not longer turns on and off but now it has a kind of pulsing picture. Am I looking at a new bulb? a new color wheel ? or some other surprise that I haven't heard about?
Lamp is possible especially if the ballast was bad--it powers the lamp.
Color wheel will usually display some issues--high pitched whine or fan like noise---with the lamp removed look where it faces--color wheel is there--any broken or missing pieces and it is the problem---
The wheel is directly connected to the set---set will detect if wheel not moving or moving too slow etc and almost instantly turn the lamp OFF.
Apr 30, 2012 | Samsung HL-67A510 67" DLP HDTV
Loud noise coming from Lamp area
The fans in these generaly do not go bad, the part nubmer for the lamp cooling fan is 265943. But my guess is that the color wheel is starting to go out of you light engine. I am not sure if these are still avalable but the part nubmer for it would be 267888. Worst case you could send your engine in for repair engine nubmer should be 265864 or order a repacement try this site. GOOD LUCK http://www.moduslinkptstvboards.com/Default.aspx
Aug 13, 2009 | RCA HD50LPW165 50" Rear Projection HDTV
High pitch noise on Notebook when Fan is on
the only two moving parts in a computer are the cooling fan and the hard drive.  Some fans have two speeds.
Mar 22, 2009 | HP Compaq Presario V2000 Notebook
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
The lamp fan is making a vibration/noise
if the frequency of the sound changes more likekly you have a bad color wheel, if a certified service center is working whit it, call hitachi costumer service problably they will pay forr the light engine(where the color wheel is located)
Dec 02, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and...
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Dan
Jul 22, 2008 | Televison & Video
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
SAMSUNG DLP BUZZ ONLY WHENBULB IS ON
A friend of mine does warranty work for samsung ,name is chip call him if you need too! 256-778-0300, most of the time when lamp needs replacing set will not play,the fan behind lamp is there to keep lamp cool when playing ,DO NOT touch lamp if you do this will leave fringer print and lamp will burn your inprint on it when hot!!! then you will have to replace lamp ,they are not cheap.replacing lamp is fairly easy, besides i really dont think lamp is your problem,most likely it would be fan making noise.
Jan 18, 2008 | Televison & Video
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Fan noise?
does it sound like grinding ball bearings? like a bad computer fan? Hate to break it to you but it is the color wheel(part of the light engine) $900 part about $350 labor, and if the tv is out of warranty your out of luck. (happened to me)
Oct 31, 2007 | Toshiba 56MX195 56" SDTV
Samsung DLP HL-P5663W 56" TV Logo
218 people viewed this question
Henry  Thomas
Henry Thomas
