How to use my cd burner
Have Windows XP computer and cd burner. How do I burn a cd
    Novelist:
  • 169 Answers
Windows XP has built-in CD/DVD burning support, but it is very basic. Simply right-click on any file you wish to burn and choose "Send To" then select your DVD drive. Doing this will add the files to your "burn queue". At any time after that, you can click "File" then choose "Write Files..."
Or, you can use a better program like Nero or Alcohol 120 ...or about 1000 other CD/DVD burning programs on the internet. It's really a matter of personal preference, and price :)
Hope this helps - remember to rate :)
Scott
Posted on Oct 06, 2008
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
Can't load my burner
The CD Burner drive is compatible with your Windows XP the software version is where the problem is. You need to get an updated version of the burner program, something like Nero burning ROM or Roxie EZ CD creator.
Buddy
Corporate Computer
May 15, 2010 | Acer (99.B0112.102) CD-RW Burner
Computer doesn't let me use CD or DVD Burner. No firewall or default problem. windows XP home
i think the administrator has blocked or disable the cd rom. for burning you must have a previlage to burn. that is known as burn right.
Feb 18, 2010 | Computers & Internet
Can't burn CD on Windows XP
yes u can burn cd on windows xp but u should have Cd burner by which u can burn cds by right clicking the data and send to .. select your cd-rw and send it after on left side click on write this on cd someting like this will show u in cd-rw window
May 18, 2009 | Microsoft Windows XP Home Edition for PC
Cant burn a CD/DVD on the Samsung DVD-Rom SD-616Q
This unit can read most formats, but it doesn't support write operations.
Mar 26, 2009 | Microsoft Windows XP Home Edition
My windows xp dvd/cd burner wont burn
Hello
Does your DVD drive detect data dvd's or cd dvd's?
if not, it seems like a hardware problem and needs to be replaced...
Feb 21, 2009 | Microsoft Windows XP Home Edition
Redone windows xp.... now cant burn dvds
There are dozens of free perfect functioning  burning software. the one that i use is Totally Free Burner 3: as the name says it's free, extremely small ( just 1 MB compared to 100MB for Nero), fast and very easy to use. get it from here http://www.softpedia.com/get/CD-DVD-Tools/Audio-CD-DVD-Burning/Totally-Free-Burner.shtml
Jan 21, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Window media player
This would be Known As A conflict, ( With I.Player )
Why Don,t you try installing Another CD Burning Program. Neros Not The Only One.
Try Roxio Easy CD/DVD Creator, Or Look On The Internet For Burner Software For Download.
Posted @ 20.57PM ( G.M.T ) :)
Mike @ Compurepair.
Mar 02, 2008 | Samsung (sw-248f) CD-RW Burner
Iomega CD-RW 52x24x52 External Burner wont burn
have you checked the web site for drivers update and which burning software are you using if you are using on board xp stop using this and got for nero burning if you are on xp sp1 and try and upgrade to xp sp2 or win 2000 sp4 and clean cd lense and try that if same resaults it's time to redo windows as you may have currupted dll files and change usb leads over if possable
Aug 13, 2007 | Iomega (32885) CD-RW Burner
Computers & Internet Logo
349 people viewed this question
David Payne
David Payne
