Question about Nitro BMW-481 Car Audio Amplifier
481 doesn't work
OK, here's the background. Installed about 2 weeks ago and it worked fine. Bettery went dead a couple of days ago and after the car was jumped it quit working. Both the radio fuse and the amp fuse were replaced, all the wiring checked. When the power is turned on, the red light lights momentarily, but the green power light never comes on. The unit lights up like power is there, but the unit will not start.
Ideas?
    Problem Solver:
  • 12 Answers
Did that to mine. Bat went dead and went to jump the car. What happends is when you attach the jumper cables, it surges the power to the amp. This gets worse with caps. I would say you blew the relay in the amp and needs to be replaced. It is worth fixin but youll have to send it off or take it to a repair shop to have the new relay put in
Posted on Oct 23, 2008
Car is "dead" but battery/alternator/starter are all in working order. Hornet is causing this.
Sounds more like a faulty battery terminal to me from your description ,try cleaning and make sure its tight then smear with petroleum grease.Clean terminal with a kettle of hot water first
Jul 26, 2013 | Cars & Trucks
Jensen cd player no longer working(self-installed)
First check the wiring to the radio. You may measure the power being ok but you also need to make sure the ground connection is ok. If this is all ok it may be that you have dry solder joints on wiring socket inside the radio or a blown track or protection diode.
Sep 17, 2009 | Car Audio & Video
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Battery goes dead
You need to Check out the Alternator.
Jan 17, 2009 | 1995 Ford Thunderbird
Tail lights,parking lights and dash lights not working
If signal lights are working, probably a failing headlight switch. Even though fuses seem OK, you can try replacing the appropriate fuse.
Jun 14, 2017 | 1998 Oldsmobile Aurora
Security system-passlock
I hav a 1995 88 w/ same problem. Key was worn out, Had Security system disabled.by installing a resistor to by pass Sec. System.Had it done for $35.00 Check locally for a starter/alternator shop in your area.
Jan 05, 2009 | 1998 Oldsmobile Intrigue
All the lights of my gateway MT3418 are on, but screen is black
Can you see a background image when get really close to the screen?
Cheers
Sep 24, 2008 | Gateway MT3418 Notebook
Nitro BMW-481 Car Audio Amplifier Logo
202 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
