Question about LG LM-2430C2L Cool Mini Split Air Conditioner
RUUD Silhouette II
Having air flow problems with my RUUD Silhouette II. The air flow decreases then eventually completely stops. The pipes leading from the house to the fan and compressor outside have a thick layer of ice. Water is also dripping into the pan up in the attic. Is there an LED fault/trouble indicator on the Silhoette II? Any ideas what is causing the trouble?
    Problem Solver:
  • 14 Answers
You will need to let the indoor fan run for several hours to defrost the indoor coil. it may take 12 hours to defrost you'll know when it's clear when the vents are blowing like usual again. Then run the unit for 5 minuits and check the large copper insulated line going to the outdoor unit. is it cold? if not you need a refrigerant charge. If it is then make sure never to run the unit below 70 degrees and check your air fliter and return duct for blockage of possible collapse. Also you may have a dirty indoor coil chac that and clean the outdoor one as well.
Posted on Jul 27, 2009
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
My ruud silhouette II gas furnace starts up and runs for 15 mins. or so and shuts off. just replace thermosta and filter. ??
are all the vents in the house full open?
is the flue vent pipes clean and un obstructed?
be sure none of your ductwork on the air return side is collapsing restricting airflow when the blower tries to run.
Is the draft inducer fan coming on?
could be a bad high limit switch.
Jan 05, 2011 | Heating & Cooling
My furnace comes on and heates the house for about
Make sure filters are clean . if they are stopped up the unit will over heat. Lets start there. Russ
Mar 22, 2010 | Ruud UBHC Air Conditioner
Sticky manual gas valve
Sounfds like the thermostat is on the blink.?
Oct 17, 2009 | Heating & Cooling
How do you change the air filter on a Ruud silhouette II furnace? Where is it located?
If it is a down flow, it will usually be found in the return air plenum just above the blower. You need to remove the front panels and look inside above the blower. You may need to remove a second door to access the blower section. If it is an upflow, remove the bottom door and look alongside the blower where the return air comes in.
Oct 04, 2009 | Heating & Cooling
My ruud silhouette ii gas furnace is blowing regular air. i know nothing about a/c? is it freon?
Check outside unit to see if it is working. If fan is blowing outside put your hand over unit to see if air is warm. If outside unit is running and air is cool. Low on gas or compressor not running. You need to call a service tech to check it out. Also check the brreaker on outside unit. Russ
Jul 23, 2009 | Heating & Cooling
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Heating & Cooling Logo
345 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
