Question about Panasonic NN-2505A Microwave Oven
NE1856 Microwave I have a F81 error on 2 Microwaves - is this just a co-incidence? or is is a power problem.
Error 81 message is usually a fault in a relay....found on the LV transformer located beneath the noise filter....(noise filter is a ciarcuit board mounted to one side, should see 2x 10a fuses on it and a small 1.25A)...underneath, a circuit board...thats the lv transformer assy.
Check the 10A fuses first....if they are ok, change the entire transfromer assy.....easy enough to do, the part number is A692M3310GP
Hope this helps
Posted on Oct 29, 2008
What does E 13 mean on a Kenmore microwave oven?
Kenmore microwaves are made by several manufacturers. The E-13 error may indicate a humidity sensor issue or a problem with the control board. It could also be an issue with the wiring between the sensor and the control board. Try unplugging (or turning off the circuit breaker to) the microwave for at least 30 seconds. This may reset the error. If the problem recurs, the sensor or the control board may need to be replaced. Microwaves can store an enormous amount of power in the capacitor and may be dangerous. Repairs are best done by a professional.
I hope this helps.
(The E-13 code diagnostics above apply to Samsung-made microwaves.)
Mar 12, 2016 | Kenmore Microwave Ovens
Why does the 1.3A fuse keep blowing on the power board of a Panasonic NE1856 microwave oven.
most likely a defective component (capacitor, or resistor, relay, etc.) is drawing more than 1.3A (ampere).
Oct 07, 2015 | Panasonic Microwave Ovens
Why doesn't it turn on?
The internal fuse may have opened.
Sep 25, 2015 | Microwave Ovens
Error code F81
A short somewhere and bad if it blows instantly--a shop repair as could be control problem or bad inverter(power for the unit) or even a bad magnatron---someone who knows their way around in this type of unit would have to make some tests---both the inverter board and the magnatron are over 100 each parts.
Jun 16, 2012 | Panasonic NE2157 - Pro I Microwave Oven,...
My LG microwave Model No MG555F made a loud explossive sound while warming rice gruel and continued to work normally; the incident repeated while I was warming fried fish; the machine continued to wor
The sound you heard was an internal ARC/Short in the Magnetron which creates the microwaves, This is an imminent sign of complete failure, Due to the decrease in prices of new microwaves it is no longer economical to repair them so start looking for a good special on microwaves.
Mar 04, 2012 | Microwave Ovens
I purchased a hinari s/s microwave 77505883999 from tj hughes but it had no manual with it or the glass turntable and ring for inside microwave so they told me to go online and put in details of micro and...
Are you sure the number you have given is the model #? It looks more like a serial number. Most of the Hinari model numbers start with letters (eg. MX or EMX)
I found a website in the UK that sells parts for Hinari Microwaves ... > http://www.espares.co.uk/search/microwaves/hinari/p/1095/1032
Hopefully that helps...
Aug 08, 2011 | Microwave Ovens
When turned off after cooling for 5hr. The outside unit buzzers as if a motor is running. it has gone on for 3hr. if I turn the unit back on it works OK just the outside unit seems to keep going.the out...
Do you mean after cooking for 5 hours? If so, yes. This is normal behavior. The microwave is running an internal fan to cool the components inside of the microwave. The fact that it has done so for 3 hours is a bit strange, but I doubt there is any issue with the inverter. Watch for errors. Error F33 or F34 mean an excessive heat build up in the microwave. Errors F81, F82, F83 and F84 mean that there is an issue with power delivery, such as inverter failure. While F86, F87, F88 and F89 represent shorted contacts within the microwave's boards and power supply.
Hope this helps,
~KenjiFox
Jan 07, 2011 | Panasonic F606Y6G00CP F606Y6G00CP Inverter
Oven won't heat food
Bad Magnetron. Unfortunately, and especially on high power microwaves, magnetrons do die. They'll probably run you between 100 and 300 dollars to replace. If you believe that your microwave is within warranty(not likely), contact the manufacturer for repairs. Otherwise, it may just be cheaper to purchase a new microwave.
Sorry that this answer doesn't produce a happy result, but it's an unfortunate fault of microwaves as a whole.
Apr 23, 2010 | Maytag MMV5186A Microwave Oven
How to get hold of a manual to re-programme my ne1856?
While that one is not listed, you can find similar ones (probably one close enough to yours to work for you) here.
Otherwise, visit http://panasonic.net, select your country, then look for customer support.
Feb 05, 2009 | Panasonic NN-2505A Microwave Oven
Panasonic NN-2505A Microwave Oven Logo
985 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
