Question about Kenmore 43042 Front Load Washer
Kenmore Washer won't spin
Just moved my washer and dryer (they stack on top of each other) and now the washer won't spin. Washer is Kenmore, model number 417.47102701 Made sure there was a normal load in there and it makes appropriate noises but won't spin. Any ideas? Arrrgggghhhhh.....
  • Harry Slaughter
    Harry Slaughter Nov 20, 2008
    After moving my washer of this same model, it also no longer works. Belts are intact and it spins a bit once in a while, but mostly just "hangs" and does not cycle through.
    It worked perfectly before I moved it into my new place. It was a 500 mile move in a truck. Could a bit of bumping around in a truck damage a washer like this?
  • Harry Slaughter
    Harry Slaughter May 11, 2010
    After inspecting the washer, I discovered that there was damage to the box behind the cycle selector knob.
    I didn't think to secure the drum before I moved the washer, so it was free to bounce around inside and apparently slammed into the switch, bending and disconnecting it.
    I managed to bend it back somewhat and attach the connector. It now works again.
    Secure those drums before moving a washer! :)
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!##
Posted on Oct 01, 2010
    Problem Solver:
  • 10 Answers
90 percent chance if you replace the lid switch all your problems will go away
Posted on Jun 10, 2009
Kenmore stack top loading washer and dryer
kenmore washer won spin YouTube
Kenmore is sold by sears so go to
http://www.searspartsdirect.com/
Enter your model number to get user manual, parts diagrams parts lists and order parts.
Model numbers are usually covered by the lid or door.
Oct 01, 2014 | Washing Machines
Can stacked washer dryer be separated?
no that's a one peace stacked washer,dryer
Nov 27, 2017 | Kenmore Dryers
I have a kenmore stacked washer/dryer. It's a top
With the sympthoms your describing its sounds to me as if the timer is going to be the problem. IT could be a lid switch problem but since it does drain i can pretty much eliminate the lid switch,or even the motor and narrow it down to the timer.
Reply with the entire stack unit model number as found on a label inside of the DRYER door and i will give ya the part number for the washer timer.
GENE
Sep 17, 2011 | Kenmore Washing Machines
My model 4`7 kenmore washer does not spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Kenmore 98702 Stacked Washer/Dryer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Kenmore Model 94812301 Stackable Washer/Dryer
    try adjusting the feet on the bottom. apart from that the bearings may need replacing.
    Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
    Kenmore stacked W/D will not agitate during wash cycle
    hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
    Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 43042 Front Load Washer Logo
    97 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
