Question about Sony KP-53HS10 TV
Screen Glare We just moved our Sony rear projection TV to a new location and the screen has so much glare we can't see it unless we make the room very dark. We only have one wall where the TV will fit so we can't move it. We have windows on both sides and we have windows behind where we sit to view the TV. (Large "Great Room" with den, dining room, kitchen combination). We hope someone can give us recommendations on a glare reduction screen that might help. We live on a golf course and don't want to lose our beautiful view just to watch TV! We contacted Sony corporation and they said the screen already has a glare reduction film from the factory so they don't recommend any other options. We appreciate any suggestions that won't cost us more than the TV is worth to correct this problem!
    Genius:
  • Sony Master
  • 1,148 Answers
I know how that is,,,weve got blinds then some curtains,,if im watching a movie or playin a game,,i will shut the curtains,, you can also ajust the color 2,,,good luck
Posted on Oct 05, 2008
S.N RS051DL103300. I just want to know if you sell a protective screen that is anti glare?
Anon. Protective screen that is anti glare, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NuShield Anti glare Films In TV Room Design
FAQ Answers for Questions on our TV Screen Protectors
TV Screen Covers ScreenProtek
How to rid your HDTV of reflections
May 26, 2016 | Televison & Video
Reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
Mar 19, 2014 | Samsung 51 Class Plasma 1080p 600Hz Smart...
Need to replace a cracked screen, where can i find one or have one made?
If JVC does not have it you are likely out of luck, if the outer protective screen it might be possible to have a piece of plexiglass cut and put in but the original was anti glare coated so you would likely have a glare issue.
Dec 14, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Picture has glare
The outer screen has a anti glare coating--direct light on the screen will cause some glare.....
Dec 03, 2012 | Mitsubishi WD-60638 DLP TV
Tv works but has red glare on screen
You have contamiated fluild in red tube remove old projection fluild and put in New this should then give you a clear picture. call Mats for projection fluild 1-800-628-1118
Sep 18, 2009 | Televison & Video
Glare-can we remove plasting sheeting on screen?
yes, you need a philips screwdriver, pull the speaker grill off, remove the 4 or 5 screws along the bottom of the screen assembly, unlock the 2 electrical plugs and remove them from their ties, lift up on the screen assembly and remove it. turn it upside down and remove the 4 screws holding the bottom of the frame on, remove frame bottom, slide screen protector out, re-assemble, bingo, no glare.
Sep 08, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Reflection and glare on a 55'' Mitsubshi projection TV
I have the same problem with my Mitsubishi and the only solution I have come up with is slightly moving the TV's angle so the reflection is not as bad and closing drapes or curtains. Also turn off lamps. This is a poor design but Mitsubishi is not the only TV that has this type of problem. It is something I have become accustomed to and do not notice it as bad since I have moved the TV angle.
Jul 31, 2009 | Televison & Video
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Sony KP-53HS10 TV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
