SOURCE: Reset Bios Password on a Dell Poweredge 2850
The following information was found here http://www.darklab.rutgers.edu/MERCURY/t15/pe2850dell.html
This should take care of your issue.
Password Jumper
Place the jumper on both pins to enable the password. To disable the password, remove the password jumper.
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
SOURCE: I have a Dell PowerEdge 1500SC that is powering off
usually this would mean the process is overheating or bad,tell me this do you hear beep codes 1 1 2 indicate processor failure.So reboot and pay attention to the beeps repost and i will try to help you further.
Good luck
SOURCE: Cannot Boot Dell Poweredge 1650. Stuck on Dell splash screen
May be a HDD error or possibly a virus.
SOURCE: dell poweredge 830 server orange flashing light
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
